When I have the settings like that -
http://i.imgur.com/EBjqoo3.png - will all of my existing series, the series folders, files totally stay unchanged?
If I remember it right, some or all of the options on that screenshot are checked, so that means by default your series would be moved and renamed, is that right?
Same as movies;
It does not matter what you check on the settings - as long as you don't click "rename and cleanup" nothing will ever happen to your files
Just curious - what structure do you have?
OK, thank you, myron,
So, better avoid clicking "rename and cleanup".
Well, actually I do not have a special structure for the movies, just one single folder for all of them. If I get movies together with other files belonging to a movie (sub titles, images, txt files etc.) I put them in a sub folder of the movie folder.
Series:
http://i.imgur.com/fEBueUH.png
So, these settings ("Film Dateien umbenennen") -
http://i.imgur.com/EBjqoo3.png - are effected only when you click "rename and cleanup"?
Thanks again.
