2006-11-22, 15:03
fdrzrich Wrote:Hmm, weird then, I'm also on build 6000...no secpol.msc or sec.msc found....very strange. Any ideas why I dont have it?
The instructions for changing settings are here, http://forums.xbox-scene.com/lofiversion...20929.html - post from 'ebob9' about half way down....let me know if it works!
That one works! :-)
I have an older installation of XBMC from May 2006. I changed the settings according to the post and voila. Shares work again. (tho not long named shares).
Quote:Ok, after some major tweaking, I got XBMC to communicate with Vista SMB shares.
Using Vista B2 build 5472.5, and a fairly recent T3CH XBMC build
I did it by editing my local security policy, among other things. I made a bunch of changes, all of which will make your Vista machine less secure, so be forewarned.
Here's what I did:
1) Shared folder containing files.
2) Made sure folder had "everyone" added as read, list, and execute permission to files
3) Checked share permissions, made sure that "everyone" had read permission to share.
4) Open a command prompt (cmd.exe), type mmc and hit <enter>
5) Vista will prompt for elevated security access for MMC, allow it.
6) When MMC loads, under file, select "Add or Remove Snap-In".
7) From the list of Snap-Ins, highlight "Group Policy Object Editor", hit "add".
8) A dialog box will appear, pick "Local Computer".
9) Hit 'OK'. You now should be back at the MMC panel
10) In the explorer pane, expand "Console Root" -> "Local Computer Policy" -> "Computer Configuration" -> "Windows Settings" -> "Security Settings" ->
"Local Policies". Click on "Security Options" under "Local Policies".
11) Under "Security Options", I made the following Changes:
Network access: Allow anonymous SID/name translation: Change to Enable
Network access: Do not allow anonymous enumeration of SAM accounts - Change to Disabled
Network access: Do not allow anonymous enumeration of SAM accounts and shares - Change to Disabled
Network access: Let Everyone permissions apply to anonymous users - Change to Enable
Network access: Restrict anonymous access to Named Pipes and Shares - Change to Disabled
Network access: Shares that can be accessed anonymously - I added my root share name here
Network access: LAN Manager authentication level - Change to LM & NTLM, send NTLMv2 if negotiated
12) Close MMC.
13) open up command prompt (cmd.exe) again.
14) type GPUpdate /force
15) Reboot PC and XBMC
This is what worked for me - you may need to do less or more for yourself, but things are working ok for me now. XBMC still prompts for a password every now and then, however if I leave them blank, it will pass through ok.
--ebob9
