Full Version: How to scrape TV-Shows correctly?
I cannot get the series scraping to work
I have this structure: http://i.imgur.com/KFbbw2X.png
and these settings:
http://i.imgur.com/0UGTBVF.png
http://i.imgur.com/zkJiTCu.png
tMM shows: http://i.imgur.com/kvxSdbF.png
What am I missing?
what is your datasource set to?
i guess it should be i:\vorübergehend\serien?
TvShows have only one level.
The first folder in the datasource is always the TvShow Name
Many thanks, myron,
Yes, I have changed the data source, now tMM shows something like: http://i.imgur.com/Te0xpdc.jpg
How could I correct it?
Many thanks again.
without logfile i cannot say anything.
But since you had multiple datasources prior to your current setup, the best is to delete the database (Tools -> recreate DB) and start over...
Thank you, myrron.
Quote:without logfile i cannot say anything.
"Show error log" in "Tools"? When I click it that appears: http://i.imgur.com/mJoMmDh.png
Quote:But since you had multiple datasources prior to your current setup, the best is to delete the database (Tools -> recreate DB) and start over...
I cannot find that item, do you mean "initialize database" in "Tools"? I had done it, had clicked "initialize database" a few times without solving that problem.
- check Setings -> general settings -> LogLevel and set it to DEBUG
- do an initialize database (= delete TMM DB)
- restart TMM
- click update datasource for TvShows
- fill out TMM Menu -> Bug Report and check to add logfiles & config
Ah, great, that is a very understandable explanation, thank you very much.
Is it a log file like - tmm.2014-04-01.0.log.gz - stored in folder "logs"?
Many thanks.
