I've been having lock ups on beta 3 of XBMC in OpenElec. I and debugging enabled but I'm not sure how to post it in a box like some do. Here is a link:
http://pastebin.com/ZFFzWDTu
Have any devs looked at this or do any of the nightles fix it? I've always been told to post a debug log so I did. This is from the "xmbc.old" log as I read that is the one I want because I want the log from before the machine crashed.
I just tried a nightly from a few hours ago and a video froze just 5 minutes in so I went back to beta 2. Should I be taking this up with OpenElec with the debug logs or post here since OE really just runs XBMC?
Can you remove:
Quote:15:14:15 T:140616516220672 NOTICE: script.tv.show.next.aired: ### getting series info for #260449 - Vikings
15:14:16 T:140616516220672 NOTICE: script.tv.show.next.aired: ### data update finished
that nasty script?
You think the tv next aired script is my problem? I'll get rid of it right away.
EDIT: They announced Beta 4 today and I'm running that now. Should I still get rid of the tv show next aired script?
EDIT #2: I tried uninstalling it but it couldn't because my skin (Aeon Nox 4.1.9.7) needs it. If the script is really causing the lockups I'll consider another skin.
(2014-04-05, 17:06)fritsch Wrote: [ -> ]Aeon Nox 4 for Gotham?
Yes, Just had another freeze while I had a movie on pause. Here is that log:
http://pastebin.com/p4Nqvpzz
I see "NFS: sending keep alive after 180s." a number of times. Could my nfs shares be causing this? If so, I'll build a new database with SMB.
I think the point was that Aeon Nox 4 is Frodo only - you need 5 for Gotham (I believe - I use Confluence, so what do I know)
EDIT
Ah, I can see that there's a 4.1.9 for Gotham as well as the WIP that is 5.
Reproduce with default skin and without that next air script first.
In order to not use that script I have to not use the skin so I'll test on Confluence I guess.
Exactly - that's what fritsch was asking with the "default skin" comment. It'll help isolate the problem between core XBMC and an addon (skin or something else).
Nothing really obivous in the log - despite the next aired script is still running ...
I'm ditching nfs and going back to SMB. Will report back.
Well I have time on my hands so I switched everything to SMB. I had my family over and watched 2 3D movies and I scrolled through all my movies and TV shows to show them XBMC. After they left, I cam back to watch a show and when I hit TV SHOWS I got a black screen and a freeze, ARGH.
http://pastebin.com/fUb5ATtx
I'd ask if it was skin or script related but I had the freeze on Confluence also, although TV Next Showed was probably still on.
I never had a single freeze on OE beta 2.
