Full Version: Amazon Fire TV for XBMC
(2014-04-12, 02:36)Netix Wrote: [ -> ]
(2014-04-12, 02:20)ilovemymac Wrote: [ -> ]Anyone know how this could be used overseas and still access amazon Netflix and Xbmc stuff? Or is it possible
Yup with http://www.unblock-us.com/ .. never tried it but saw it earlier in this thread..!
Correct, only thing that doesn't work somehow is YouTube on the FTV, get a 'unavailable / pricing unavailable' message when trying to 'install' (create a shortcut). But XBMC - YT plugin works.
(2014-04-11, 23:19)thess Wrote: [ -> ]Remote tangent, the fix for the Ortek MCE IR problem I mentioned earlier (up/down keys getting double pressed) was to set the device 'command repeat' in the Harmony software for the device to 1. (Not 3, not 0, 1.) NOW I have my Harmony remote fully controlling the Fire and XBMC the way I want it to. (*Thinks about making snarky "boyfriend acceptance factor" joke, refrains*)
I have a generic IR learning remote and I'm having the same issue with the Ortek Remote. I've tried hold the buttons down for different lengths of time and at different spacings, but nothing is working. So while the Ortek remote is much nicer than I expected for $12, I'm pretty much right back where I was.
Update: I actually got it to work. I read through this guide: http://www.remotecentral.com/features/irtips.htm
I used the fly boy method (start the remotes far apart and fly in quickly while holding the transmitting button from original remote) from that guide in a dark room with no monitors and after a few tries it works.
This Gotham build should bring you passthrough (to be enabled in audio settings, of course): http://mirrors.xbmc.org/test-builds/andr...bi-v7a.apk
(2014-04-12, 06:08)jsp1 Wrote: [ -> ]I would like to report my results. I have tried all available builds from this thread and original XBMC for Ouya is still the winner.
Note that the Ouya (12.3.2) and SPMC 12.3.3 builds had a nasty bug that made vids stutter beyond the ~60min mark due to a memory leak.
So not recommended above SPMC 12.4.2 or Gotham...
Conflicting info re video codecs:
https://developer.amazon.com/public/solu...ifications says VP8 is supported but not VC1
http://www.amazon.com/Fire-TV-streaming-...5P8FC#tech says VC1 is supported but not VP8
(2014-04-12, 11:28)Koying Wrote: [ -> ]This Gotham build should bring you passthrough (to be enabled in audio settings, of course): http://mirrors.xbmc.org/test-builds/andr...bi-v7a.apk
Testing now. I'll update on results shortly.
Ok, tested the build using this video as a test (libstagefright on / mediacodec off)
PHP Code:
General
Unique ID
208341318514337433355858398794803106051 (0x9CBD1411E3FB15778CC2355ED528D103)
Complete name                            Z:\Super Heros\The Avengers.mkv
Format
Matroska
Format version
Version 4 Version 2
File size
6.85 GiB
Duration
2h 22mn
Overall bit rate
6 863 Kbps
Encoded date
UTC 2013-03-03 16:35:03
Writing application
mkvmerge v6.0.0 ('Coming Up For Air'built on Jan 20 2013 09:52:00
Writing library
libebml v1.3.0 libmatroska v1.4.0
Video
ID
Format
AVC
Format
/Info                              Advanced Video Codec
Format profile
High@L4.1
Format settings
CABAC                   Yes
Format settings
ReFrames                4 frames
Codec ID
V_MPEG4/ISO/AVC
Duration
2h 22mn
Bit rate
5 217 Kbps
Width
1 920 pixels
Height
1 072 pixels
Display aspect ratio
16:9
Frame rate mode
Constant
Frame rate
23.976 fps
Color space
YUV
Chroma subsampling
4:2:0
Bit depth
8 bits
Scan type
Progressive
Bits
/(Pixel*Frame)                       : 0.106
Stream size
5.21 GiB (76%)
Writing library                          x264 core 130
Encoding settings
cabac=ref=deblock=1:0:analyse=0x3:0x113 me=umh subme=psy=psy_rd=1.00:0.00 mixed_ref=me_range=16 chroma_me=trellis=8x8dct=cqm=deadzone=21,11 fast_pskip=chroma_qp_offset=-threads=lookahead_threads=sliced_threads=nr=decimate=interlaced=bluray_compat=constrained_intra=bframes=b_pyramid=b_adapt=b_bias=direct=weightb=open_gop=weightp=keyint=240 keyint_min=24 scenecut=40 intra_refresh=rc_lookahead=50 rc=crf mbtree=crf=20.0 qcomp=0.60 qpmin=qpmax=69 qpstep=vbv_maxrate=62500 vbv_bufsize=78125 crf_max=0.0 nal_hrd=none ip_ratio=1.40 aq=1:1.00
Language
English
Default                                  : Yes
Forced
No
Color primaries
BT.709
Transfer characteristics
BT.709
Matrix coefficients
BT.709
Audio
ID
2
Format
DTS
Format
/Info                              Digital Theater Systems
Mode
16
Format settings
Endianness              Big
Codec ID
A_DTS
Duration
2h 22mn
Bit rate mode
Constant
Bit rate
1 509 Kbps
Channel
(s)                               : 6 channels
Channel positions
FrontL C RSideL RLFE
Sampling rate
48.0 KHz
Bit depth
24 bits
Compression mode
Lossy
Stream size
1.51 GiB (22%)
Language                                 English
Default                                  : Yes
Forced
No
Menu
00
:00:00.000                             en:Chapter 1
00
:08:02.315                             en:Chapter 2
00
:11:49.166                             en:Chapter 3
00
:15:18.751                             en:Chapter 4
00
:20:33.482                             en:Chapter 5
00
:23:04.257                             en:Chapter 6
00
:29:39.444                             en:Chapter 7
00
:37:23.991                             en:Chapter 8
00
:42:47.982                             en:Chapter 9
00
:50:22.269                             en:Chapter 10
01
:01:04.661                             en:Chapter 11
01
:14:05.107                             en:Chapter 12
01
:28:01.234                             en:Chapter 13
01
:38:20.561                             en:Chapter 14
01
:45:40.167                             en:Chapter 15
01
:51:15.085                             en:Chapter 16
01
:57:47.769                             en:Chapter 17
02
:04:38.679                             en:Chapter 18
02
:09:39.396                             en:Chapter 19
02
:13:10.691                             en:Chapter 20
The video played as smooth a butter all the way through. No frame drops, judders, stutters or anything else that I noticed. DTS pass-through also had no issues (haven't tried DD yet).
The only issue that I have now is that every time I start XBMC I have to manually set the audio mode on my AVR for the first movie I play. Once I set it for the first one then everything is fine, but if I don't then I get the static/noise issue. This is probably because I have a Denon AVR and is probably not an issue with other brands.
I have to say this is probably a keeper. Great job Koying.
(2014-04-12, 11:44)Koying Wrote: [ -> ]Conflicting info re video codecs:
Sorry I've asked these questions before but they've been buried by questions about pass-through and remote controls etc.
Who is it that works on getting MediaCodec working on new hardware ie the adreno 320? Libstagefright and software based decoding with multithreading stutter on my divx/xvid videos. While my old OUYA with mediacodec plays them smooth. Is it XBMC that does this, or is there a MediaCodec team? How can I get involved?
Also, do you know why it is that when I'm running libstagefright my cpu usage is at like 30 percent across only 3 cores, and then when I switch to software multithreading I get the exact same results, about 30% across three cores. It's as if making the change to software decoding did nothing.
Thanks Koying.
Full passthrough? Or no HD still? Thanks again and thank you for pointing out the bug in the Ouya release. I haven't experienced it yet, but it is good to know about. I guess update is imperative.
(2014-04-12, 13:57)Tinwarble Wrote: [ -> ][deleted]
Greatest American hero awesome sorry had to
Hi everyone.
Been using XBMC for years now on other devices. But just got my Fire TV and loaded Koying's Beta 4 just posted above in post #1098.
It's running really slow. Frame rate is really bogged down. Noobie question, does this have something to do with the mediacodec needing to be turned off and libstagegright turned on?
If so, how do I turn them off/on?
I've done some searching of the forum already, it it seems libstagefright is built into all the latest xbmc nightlies for awhile now, so I'm assuming I have to merely figure out how to disable mediacodec?
Or just hardware decoding in general from within XBMC? Not finding it.
Looking forward to giving an update for eveyrone's benefit once it starts playing smoothly. All help appreciated!
Deleted due to being well intentioned, but wrong in almost every particular.
@ Rational,
Yes you need to turn mediacodec off.
Go to Settings > Video, then make sure you change the "Settings Level" to "Advanced" or "Expert".
You'll then see "Acceleration", select it and you should see the selections for libstagefright and mediacodec. Leave libstagefright on.
(2014-04-12, 09:32)dismantler Wrote: [ -> ]
Interesting, thanks. It's always good to have more tools in the arsenal. But I did discover one weird thing about the $12 Ortek and Harmony: using the Ortek's stock device profile in the Harmony software (once I found it), it still sent double-presses for up/down. Meaning, the 'stock' commands the Harmony thinks it should use for this device, NOT commands that I had manually learned with the Ortek remote. Adjusting the 'command repeat' to 1 on the device fixed that part. So either way it sounds like something that just needs to be tweaked from one direction or another.
Its hard to gather the the state of lossless audio for these android builds! It would be awesome if the wiki had a section about audio Smile it would make it so much easier for everyone.
Can someone that has tested these builds with a capable receiver please clear this up. You would think if it could pass through one codec it could do the lot and this maybe the case?
Ouya build im not sure about, i know it will pass dts and dd but havn't seen anything else regarding lossless.
The latest spmc 12.4.2 passes through DTS/DD and one person commented DTS-es, how about anything else?
The latest gotham (xbmc-20140412-1d32fd0-AmazonFire-armeabi-v7a.apk) is passing through DTS/DD has anyone tested DTS-MA?
(my fire arrives in New Zealand early next week, cant wait!)
