I tried to install XBMC in a Windows VM I have and upon first launching it after the install I get the following error:
"ERROR: Unable to Create GUI. Exiting."
I'm accessing my VM via Remote Desktop. It's a Windows 7 Professional 64-bit OS.
Not a common error I imagine?
if you had searched you would have seen this is a very common error when you don't have the proper driver installed or accessing though remote desktop
(2014-04-03, 14:50)Martijn Wrote: [ -> ]if you had searched you would have seen this is a very common error when you don't have the proper driver installed or accessing though remote desktop
I did a search and only found issues with people saying "unable to connect to remote server." What should I search for? And when you say it's a common error, are you saying you can't set it up via remote desktop?
