Full Version: Aspect Ratio issue on RPi
Hi all,
I have had a RPi for 6 months which has run on the latest official versions of Openelec without issue. I then bought a second RPi to place in the bedroom.
Both RPi's have the same firmware and skin (quartz) but the bedroom unit is only displaying movies and tv shows in 4:3 ratio. Whatever i have changed it reverts back to the 4:3 ratio.
Help?/
You have tried to change both PI's, I assume?
Another thing you can try is to change the config.txt to disable CEC.
(2014-04-03, 13:16)Lowdef Wrote: [ -> ]Hi all,
Help?/
Have you tried swapping the two pi's? Maybe it's the display device. Our bedroom TV is much more willing to adjust the pi output correctly than a projector (same pi, splitter in the circuit) in the family room.
