2014-04-04, 22:43
I installed the confluence mod for gotham, overwriting the global search folder in roaming, and the script functioned great in aeon nox gotham. The. For some reason after reboot it just hangs at searching movies.
(2014-04-04, 22:43)Agent62 Wrote: [ -> ]I installed the confluence mod for gotham, overwriting the global search folder in roaming, and the script functioned great in aeon nox gotham. The. For some reason after reboot it just hangs at searching movies.
(2014-04-05, 00:48)Agent62 Wrote: [ -> ]Here ya go, and thanks.
http://xbmclogs.com/show.php?id=166190
(2014-04-05, 01:20)Agent62 Wrote: [ -> ]Yes, keyboard works when i used it. I use xbmc remote ipad, iphone, and yahtsee remote on android.
Is there anything i can do on the remote side to be able to use it?
Quote:15:45:40 T:1772 ERROR: JSONRPC: Failed to parse '{"jsonrpc": "2.0", "method": "VideoLibrary.GetMovies", "params": {"properties": ["title", "streamdetails", "genre", "studio", "year", "tagline", "plot", "plotoutline", "runtime", "fanart", "thumbnail", "file", "trailer", "playcount", "rating", "mpaa", "director", "writer"], "sort": { "method": "label" }, "filter": {"field":"title","operator":"contains","value":"arthur
"} }, "id": 1}'
