Full Version: Change font size
Can I change font size? My skin is the default confluence.
In some skins, yes. In Confluence, sadly no.
Could you please help advise which skin can manually change font size?
Thank you very much.
(2016-05-27, 10:28)Andy_Lin Wrote: [ -> ]Could you please help advise which skin can manually change font size?
Since that last post was made, Confluence now has a larger font size.
Yes. But if change the font type to Arial for support Chinese, the larger font size can't be select.
Have any solution?
