Full Version: Gotham Nightlies from Beta2 ISO install
Hi all,
I installed Gotham Beta2 via the beta 2-1 iso from this thread: http://forum.xbmc.org/showthread.php?tid=189553
I want to try out the new ReFocus Gotham preview skin however the installation instructions explicitly state that the latest gotham nightlies are required. I added the Team XBMC nightly PPA however when I check the available candidate for installation, the release naming convention makes me think it's going to install an XBMC 14 nightly (which isn't what I want to do). Am I reading the naming convention wrong? Is this the wrong method?
sudo apt-cache policy xbmc
xbmc:
  Installed: 2:13.0~git20140329.0731-beta3-0trusty
  Candidate: 2:14.0~git20140406.0204-577494a-0trusty
  Version table:
     2:14.0~git20140406.0204-577494a-0trusty 0
        500 http://ppa.launchpad.net/team-xbmc/xbmc-nightly/ubuntu/ trusty/main amd64 Packages
*** 2:13.0~git20140329.0731-beta3-0trusty 0
        500 http://ppa.launchpad.net/team-xbmc/unstable/ubuntu/ trusty/main amd64 Packages
        100 /var/lib/dpkg/status
     2:12.3+dfsg1-3ubuntu1 0
        500 http://us.archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
The PPA I added for reference: https://launchpad.net/~team-xbmc/+archive/xbmc-nightly
Thanks all,
tret
for Gotham you need the unstable ppa to get the betas
(2014-04-06, 17:42)Martijn Wrote: [ -> ]for Gotham you need the unstable ppa to get the betas
Thanks for the reply. I actually want Gotham nightlies, I'm already on the latest in the Unstable PPA (Gotham Beta3). My concern is that, based on the apt-cache policy output it looks like I'd be going to an xbmc14 nightly instead of the latest xbmc13 nightly.
Thanks,
tret
I guess something else I should ask, are nightly PPA's still being built for Gotham?
correct. PPA nightlies are build from master branch and not from Gotham.
atm there is very little difference between Gotham and master (13.0 and 14.0) code wise. This will change over time as development progresses.
(2014-04-06, 17:52)Martijn Wrote: [ -> ]correct. PPA nightlies are build from master branch and not from Gotham.
Gotcha, thanks. I wonder what Jeroen's intention was when he stated that users should be on the latest Gotham nightly. I'll have to ask.
(2014-04-06, 17:54)tret Wrote: [ -> ]
All other platforms nightlies are actually build from Gotham. Linux is the exception.
Beta3 is good enough for reFocus
Understood, thanks again. I'll see what Jeroen recommends for running ReFocus in this scenario.
tret
(2014-04-06, 18:01)Martijn Wrote: [ -> ]Beta3 is good enough for reFocus
Great, I'll give it a try. Appreciate your help and speedy replies Smile
