2014-04-06, 23:57
I'm working on a client HTPC build. I have an Opteron unit as my primary server running both XBMC and PMS (easier for extranet access). However, I want something fairly light, inexpensive, but robust enough to be ready for 4K when the newer Ultra High Def TVs start coming down in price.
I have picked out most of the hardware, and I'm looking at an i3-4130t on a MB that has DP. My question is:
With Intel 4400, if I have a DP to HDMI adapter going into (presumably) an HDMI 2.0 4K television in the future, will it be able to support 4K @60hz? I know that Intel 4400 HD supposedly supports 4k 60hz via DP, but I highly doubt that the new televisions will be compatible with DP, unless I get a really expensive monitor. Plus, they state that HDMI 2.0 will be compatible with old cables. Through inductive reasoning, I would presume that a DP to HDMI adapter, into an HDMI 2.0 port on a 4K television, capable of supporting 60hz will work... however, I'm not confident enough to hit the "Checkout" button.
Thoughts?
[Not sure if it's worth noting, but I already have a BDXL drive capable of doing quadlayer. My prediction is that manufacturers are trying to move away from optical media for Ultra High Def, but I'm holding onto hope they don't.]
Thoughts?
