Full Version: GPIO IR Help (SOLVED)
I`ve bought some female to female jumper cables and tsop4838 receiver. When i type: dmesg | grep lirc_rpi
I receive the following message back from ssh:
[ 6.728070] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.631844] lirc_rpi: auto-detected active low receiver on GPIO pin 18
[ 7.632250] lirc_rpi lirc_rpi.0: lirc_dev: driver lirc_rpi registered at minor = 0
[ 7.632264] lirc_rpi: driver registered!
Then: mode2 -d /dev/lirc0
But I receive the following messages
mode2: could not open /dev/lirc0
mode2: default_init(): Device or resource busy
Im just trying to see if the receiver is working
I`ve then typed irw /var/run/lirc/lircd-lirc0 and ssh doesn't do anything.
Does anyone know where Im going wrong?
EDIT: Tried again, and its working now
Mce remotes work out of the box for me when plugged in the way this guide has it https://learn.adafruit.com/assets/5909
Mabye you need to kill lirc first?
Assuming that you using Milhouse's builds, please see this thread http://forum.xbmc.org/showthread.php?tid=184791
what addon, it doesnt say
Quote:I`ve bought some female to female jumper cables
I don't know what you use these for, but has it occurred to you that there may be either a crossover you need, or a crossover you shouldn't have in the wires?
(2014-04-08, 13:05)stuCONNERS Wrote: [ -> ]Then: mode2 -d /dev/lirc0
When using the mode2 command you should make sure lircd isn't running.
When using the irw command lircd has to run. But use:
instead of
irw /var/run/lirc/lircd-lirc0 ends in:
connect: Connection refused
This works for me with the Milhouse builds: http://wiki.openelec.tv/index.php?title=...O_Receiver
(2014-04-09, 13:08)Ned Scott Wrote: [ -> ]This works for me with the Milhouse builds: http://wiki.openelec.tv/index.php?title=...O_Receiver
I also used this guide getting gpio ir to work with Milhouse builds. Also mapped the input to gpio22 (gpio18 is used by a 16x2 lcd). Newly the irw command works as described before for me (at setup like in the guide).
(2014-04-08, 18:55)stuCONNERS Wrote: [ -> ]what addon, it doesnt say
Sure it does, the addon from *tas, see the first post of that thread for the link to the addon.
This didn't work for me, but I understand that *tas' addon does something similar so in theory it should.
(2014-04-09, 15:59)Bonzi Wrote: [ -> ]This didn't work for me, but I understand that *tas' addon does something similar so in theory it should.
This addon starts lircd at startup from xbmc/openelec
/usr/sbin/lircd --driver=default --device=/dev/lirc0 --uinput --output=/var/run/lirc/lircd --pidfile=/var/run/lirc/lircd-lirc0.pid /storage/.config/lircd.conf
You can also add this to "autostart.sh". Mine looks like this (cause of mapping input to gpio_in_pin=22):
#!/bin/sh
(kill -9 $(pidof lircd); \
modprobe -r lirc_rpi; \
modprobe lirc_rpi gpio_in_pin=22; \ #for new libgpio version
/usr/sbin/lircd --driver=default --device=/dev/lirc0 --uinput --output=/var/run/lirc/lircd --pidfile=/var/run/lirc/lircd-lirc0.pid /storage/.config/lircd.conf; \
