I have just installed XBMC Ubuntu.
I often get a popup that reminds to me update XBMC. It is annoying and I wish to disable the popup. How do I do that?
update XBMC if you are running a Gotham build.
http://wiki.xbmc.org/index.php?title=HOW...nux#Ubuntu
When you are still using Frodo12.3 there shouldn't be one.
If you are running an older one it's just a one time notify you are running an outdated build which is common for a fresh XBMCbuntu install
(2014-04-09, 13:56)Martijn Wrote: [ -> ]update XBMC if you are running a Gotham build.
I'm running 12.3 so when following the upgrade steps, it says I'm running the latest.
The popup still comes up from time to time telling me to update.
I want to disable the popup. How can I do that?
Actually, I want to clarify what version I am running.
I installed the ISO downloaded from here:
http://mirrors.xbmc.org/releases/XBMCbun...NVIDIA.iso
I am presuming that is the latest XBMC given I downloaded it directly from the site. If not, what exactly do I do to update it?
I have also done this:
sudo apt-get --only-upgrade install xbmc xbmc.bin
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'xbmc-bin' for regex 'xbmc.bin'
xbmc is already the newest version.
xbmc-bin is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 228 not upgraded.
please provide me a
Debug Log on pastebin.com so i can look at the issue to prevent this from happening
(2014-04-10, 10:50)larrikinaus Wrote: [ -> ]Actually, I want to clarify what version I am running.
this contains xbmc 12.2, while there is 12.3 available. So the update notification is absolutely correct.
wsnipex
shouldn't i update because of:
(2014-04-10, 11:20)larrikinaus Wrote: [ -> ]I have also done this:
lets see the output of:
apt-cache policy xbmc
