Full Version: service.subtitles.legendasdivx
Pages: 1 2 3 4 5 6 7 8 9
Highlander...you're the man. It works like a charm now. Thank you. Keep up the good work.
Glad to hear all is working! Smile
Hello everyone!
Higlander as I told you before I'm having some issues with my subtitles legendasdivx plugin, hope you can help me with this Wink
Here is my log file, i did the experience tonight +/- 23:30. What I did was search for an subtitle that I know that works and make the download, everything run ok. Then I searched for another one ( the one that I need! =D ) and that I know that don't work with xbmc plugin but that is working in the http. Anything you need you can PVT me Wink
XBMC Log ( Raspbmc )
Thanks in advance! =P
using Aeon Nox 5 in Kodi when using this service it does not show multiple subtitle files. The new window load in the background, and I can't select the correct subtitle. How do I fix this?
It's the layer problem in Nox. It was fixed in the previous versions but I guess that in Helix the problem is back. Try to leave a message in the skin thread. It needs to be changed in their end. When I get time I can try to submit the fix to their github but I don't know when. Thanks.
Regards.
I could ask for an invitation? Thank you.
Hi all,
I'm running Kodi 14.2 with OpenElec, and everytime I try to load a movie with subtitles LegendasDivx it gives me an error "Script Failed".
Can anyone help?
Hello @HiGhLaNdeR !!!
On the last days I get an error when searching subs!!! It won't display any sub search!!! I never had any problem with this addon, it always worked fine!!!
I'm running latest official Kodi on Shield Tv.
I also tried this on a PC but it works just fine.
http://pastebin.com/m5wCqysS
Can you please fix this?!
Check if the GitHub version helps.
https://github.com/highlandr/service.sub...endasdivx/
Swap the services.py file from the one in the GitHub.
The new version should be out next days officially.
Sent from my ONE A2001
(2016-05-19, 11:10)HiGhLaNdeR Wrote: [ -> ]Check if the GitHub version helps.
I switch the file and it worked!!!
Just for the notice, I don't think it's from the addon, maybe something from the site itself, when I try to download some subs, it fails to download (I get an error message for that). I don't have the log right now, maybe tonight or so.
Send plz. Thanks.
Hi guys,
Been trying to download subtitles for a couple of weeks, without success. Either by auto search, or entering manually, i can't get any results for the subtitles i need, even though i know they exist on the website.
Any ideas?
Kodi version? Did you choose the Portuguese language in system/settings/video/subtitles?
(2016-06-20, 01:43)HiGhLaNdeR Wrote: [ -> ]Kodi version? Did you choose the Portuguese language in system/settings/video/subtitles?
Jarvis! And yes, Portuguese. Everything was working fine until a couple of weeks ago.
Need log file. Turn on debug and send me the log.
