Full Version: service.subtitles.legendasdivx
Pages: 1 2 3 4 5
Thread for any issues/bugs and feature request for service.subtitles.legendasdivx
The service was ported from the frodo version.
## Frodo (update 06/06/2014) ##
https://github.com/highlandr/script.xbmc...tree/frodo
## Gotham ##
source code:
https://github.com/highlandr/service.sub...gendasdivx
For guidance go to http://forum.xbmc.org/showthread.php?tid=180265 and HOW-TO:Setup subtitle services for how-to setup new services on Gotham
Cheers!
HL
What a great surprise! Legendaszone soon? Big Grin
"Abra├žo! Big Grin"
Is this working with multiple subtitle zip?
I downloaded chuck s02 package and didn't open browse window and automatically choosed s02e01. Thanks
Hello!
Yes. The multi subs should be working.
There was an update released today. Check it out.
About The legendaszone i'll try to get some time to port it.
Cheers!
Hi Highlander:
I'm testing legendasdivx addon but it fails to find any subs !!
I get always same error : scrip failed !!!
What am I doing wrong ??
opensubtitles works fine.!!
Log for error:
http://xbmclogs.com/show.php?id=214280
Something related with this:
"Error Contents: 'ascii' codec can't encode characters in position 21-22: ordinal not in range(128)"
(2014-05-30, 17:37)Mafarricos Wrote: [ -> ]Log for error:
Ok I looked into the log report and I have the same error you reported "ascii codec can't etc...etc..."
What is the solution ??
If I have sometime at night I will check if I can find a solution and will make a pull request in github, if HiGhLaNdeR doesn't find any solution sooner Smile
(2014-05-30, 18:48)Mafarricos Wrote: [ -> ]If I have sometime at night I will check if I can find a solution and will make a pull request in github, if HiGhLaNdeR doesn't find any solution sooner Smile
Ok thanks.
Already made a patch:
https://github.com/highlandr/service.sub...ll/1/files
Works with me.
HILFER, you can go to the file and aply fix, if a better fix is provided your addon will update Wink
Also requested for a change to search by title of library and not filename, as sometimes filenames aren't complete or are simple. Like movie.avi, etc.
By title is more likely to find subtitles without using manual search.
(2014-05-30, 19:51)Mafarricos Wrote: [ -> ]Already made a patch:
Works with me.
What file ?? sorry I'm not very techy.Tell me what to do exactely. please.
The fix should be release to xbmc and you will get the addon updated Wink
(2014-05-31, 17:14)Mafarricos Wrote: [ -> ]The fix should be release to xbmc and you will get the addon updated Wink
Great thanks.
Hello all Smile
The version 0.0.8 was added to the xbmc repo this morning. Me and Mafarricos had a weekend of work and testing to make it work properly.
Hope everything is OK Smile
Cheers!
Good work and nice feedback Highlander Smile
Pages: 1 2 3 4 5
