Up to you, we can reverse the check value. But if we do at this point it will screw up all the people who have it set and working now.
We can add a new setting which replaces the old on and has a different default value.
People would have to change their settings again if they didn't like it but that is not too weird for a skin that is in staging.
Pulled it, looks nice. Will request pull to staging repo again.
I just noticed we did not implement DialogMediaFilter.xml in Gotham.
I am spending long hours at work so can only do stuff I know won't break - like implementing required Helix changes.
Looks like it was optional at the time:
http://forum.xbmc.org/showthread.php?tid...pid1221252
Does anyone have any experience from other skins with the dual sliders this implements? Are they remote friendly? I don't seem to be able to navigate to the right slider to move it at all without a mouse.
Pulled 59, force rebased the Helix branch on it.
I'll probably keep doing that until we stop rapid development of Gotham so don't track / do any Helix stuff. =)
The Helix branch is by the way fully up to date with the changes from the Helix skin change thread.
I intend to keep doing that so we can move swiftly over when the Helix repo opens.
Just posted this one:
http://forum.xbmc.org/showthread.php?tid=197177
and then realised it should probably just have been a post in here - sorry about that.
But instead, I'll make full use of this post and post another bug/missing element:
When beginning a search for subtitles for a movie/tv show, a blue round icon with an "!" symbol accompanied by an explaining text would appear at the bottom of the screen if local subtitles were already available. The icon is still there, but the explaining text is gone (said something like "Local subtitles available").
Keep up the great work guys!
Thanks for your work on this skin, has always been my preference on XBMC. so clean.
I just updated to Gotham, and got the latest version of Neon, and noticed something not quite right. I tend to use Media View for my TV shows, and as you can see in this screenshot, the number of episodes goes behind the other text.
Ive tried the usual thing of resetting the guisettings in userdata, and switching to different views and back, different skins.. etc. but its always the same for me.
Also the same can be seen on the episode list view (Media View again), originally aired details are hidden behind text.
thought id bring it up, if its just me having the issue, would love some other suggestions to correct it. thanks.
It is probably one of the alignment issues I missed when i was correcting them
I found a few later, not sure if they have been pulled in.
