Hi Guys,
I just purchased a new TV and I'm running into choppy playback with Match Refresh Rate to Video enabled, no matter what I try.
TV: Vizio M501 LED
HTPC: AMD A8-3850
Log:
http://pastebin.com/PZ2dJbw3
Settings:
Help would be greatly appreciated!
Try unchecking 'Use a fullscreen window rather than true fullscreen'. You might also want to check your audio settings - this is a great place to start troubleshooting
http://forum.xbmc.org/showthread.php?tid=146911.
And please stop posting multiple questions on the same subject.
Yep enabling "'Use a fullscreen window rather than true fullscreen" is most definitely not going to give smooth video.
jjd-uk
Thank you so much, that solved my problem immediately!
steelman1991
Thanks for the link, but I have already read that link as well as pretty much every other thread on stutter/choppy playback.
To be clear though, my posts, with the exception of the duplicate in the Windows support section, are completely unrelated issues.
1 was a confirmed Gotham hug with a confirmation prompt
1 was a AV sync problem that hasn't been solved
This problem was a stutter with a new tv that didn't exist with the old TV
LOL - yeah thanks jjd-uk. Was the first sentence of my post invisible?
So you had posted multiple times - once in General and 1 in Windows - those are the ones I was referring to, so I reiterate - please stop posting multiple questions on the same subject - AV Sync. 1 is quite sufficient
Its a subject which has been done to death - searching will provide you with several threads on the issue, none of which have provided a solution, particularly with 24hz playback.
Missed it on your first post. Sorry and thanks!
Is the sync problem Gotham specific?
Does it exist on all OS?
(2014-04-11, 15:09)steelman1991 Wrote: [ -> ]LOL - yeah thanks jjd-uk.
Was that the wind or did someone say something
Clearly it was the delay via satellite
(2014-04-11, 15:11)newoski Wrote: [ -> ]Missed it on your first post. Sorry and thanks!
Here's a link to the issue on Windows - don't know about other OS, haven't tried any others. Long thread and been an issue since 2010 (Dharma)
http://forum.xbmc.org/showthread.php?tid...4fps+delay
