(2014-04-15, 07:09)baijuxavior Wrote: [ -> ]Standard vga adapter means you are using generic micorsoft driver which won't work for xbmc. You should look at your motherboard specifications and check what display card it uses. Then download the appropriate driver. Post specifications of your PC and OS used for more suggestions.
OS Name Microsoft Windows 7 Home Premium
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name HOME-PC
System Manufacturer Hewlett-Packard
System Model HP dx2000 MT(DY925AV)
System Type X86-based PC
Processor Intel® Celeron® CPU 2.53GHz, 2533 Mhz, 1 Core(s), 1 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1.12, 06/12/2004
SMBIOS Version 2.3
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United Kingdom
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name home-PC\home
Time Zone GMT Daylight Time
Installed Physical Memory (RAM) 2.00 GB
Total Physical Memory 1.99 GB
Available Physical Memory 1.04 GB
Total Virtual Memory 3.98 GB
Available Virtual Memory 2.91 GB
Page File Space 1.99 GB
Page File C:\pagefile.sys
this is under the display section
Name Standard VGA Graphics Adapter
PNP Device ID PCI\VEN_8086&DEV_2572&SUBSYS_218114A4&REV_02\3&267A616A&0&10
Adapter Type Not Available, (Standard display types) compatible
Adapter Description Standard VGA Graphics Adapter
Adapter RAM Not Available
Installed Drivers Not Available
Driver Version 6.1.7600.16385
INF File display.inf (vga section)
Color Planes Not Available
Color Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Memory Address 0xF0000000-0xF7FFFFFF
Memory Address 0xFE780000-0xFE7FFFFF
I/O Port 0x0000EC00-0x0000EC07
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\vgapnp.sys (6.1.7600.16385, 25.50 KB (26,112 bytes), 14/07/2009 00:25)
