Full Version: TV Series specific options
Does anyone know if there is a way to apply video and audio options for a specific tv series instead of just all videos? I ask because it is frustrating and tedious to adjust audio and subtitle options on each play of various shows.
There is no way to do it per file/series, even the all videos doesnt apply to all videos, even though thats what that option suggests (not all options are applied either), it applies for all videos of some given resolution, so if you set options for a specific resolution or ratio for e.g. 16:9 you will need to redo for 4:3 and so on and on, and like I said not all options are applicable, for e.g main volume, only volume amplification is saved.
You can observe what I said fairly easily though to expense of some time to actually check it out.
