2014-08-13, 05:54
2014-08-13, 07:53
What's the problem here? The color? :-)
2014-08-13, 11:17
@fritsch
you can see there are garbled images (colored blocks) all over the screen. but this does not appear during playback. only in the menu.
2014-08-13, 13:30
system specs pls,
i've seen this earlier
2014-08-14, 03:38
here's the specs mate. some forum say its because i have ATI graphic card.
i3-3220
gigabyte ga b75n-itx
8gb gskill ddr3 1600
sapphire hd 6770 1gb ddr5
seagate 2tb HD
onkyo HT-s3300 Home theater
samsung 40eh6030
windows 8 64-bit
i3-3220
seagate 2tb HD
samsung 40eh6030
windows 8 64-bit
2014-08-14, 09:29
well to rule out the skin issue,
did you try another skin ?
did you try another driver for your graphic card ?
does this only happen in xbmc or also on your desktop ?
2014-08-14, 15:39
in some skins it appears also but not that much. i downloaded all skins in the official repo just to compare.
this only appears in xbmc menu not anywhere else. yes, i have tried different (older) drivers but it became worse. they said its ati problem with xbmc, never a skin. some even suggested to do linux install htpc dedicated to xbmc.
2014-08-14, 18:10
which skin is it ?
also with confluence skin ?
which driver version are you using ?
did you set all your settings like in the first topic ?
you could try a clean install of xbmc (perhaps in portable mode)
i presume you're using the latest xbmc from here 13.x Gotham ?
2014-08-14, 20:10
using gotham stable. updated with latest ati drivers. it does not appear in confluence, quartz and bello is where it is very visible.
2014-08-16, 16:31
well i would almost say it's a skin issue then if it only shows when using those skins
2014-08-28, 07:18
Hi Piers/Kodi - for sound under max number of channels, i only have 2. not 8 per your guide. why is that? can you please explain what i'm doing wrong. is it bcuz of my setup? thanks.
win 7 x64, xbmc 13.2 gotham, aeon MQ5
2014-08-28, 10:28
(2014-08-28, 08:12)fritsch Wrote: [ -> ]Post your Debug Log ...
here it is. thank you for looking at it.
http://pastebin.com/K6Fwb9zw
2014-08-28, 11:27
Whatever is connected to your HDMI out only tells us that is has 2 channels. So what is connected there?
2014-08-29, 02:08
(2014-08-28, 11:27)fritsch Wrote: [ -> ]Whatever is connected to your HDMI out only tells us that is has 2 channels. So what is connected there?
hi fritsch - the hdmi from my video card(my computer) is connected to the tv. is it suppose to go to the receiver?? if i connect it to 'video in' in the receiver, i'm not gettin any picture. sorry, im inexperience in this matter.
