Full Version: Changing Resolution via Shortcut
I would like to change between 2 set resolutions via a button on my iPad, I have done some research and cannot find an answer. I am on Gotham beta 3. Any help or advice would be much appreciated.
Kind Regards
Simon
I was thinking maybe there isa way via the Json protocol? I couldn't find much on he to do the. The iPad app I would be using is DemoPad which can send Json protocols.
Thank you
Sorry to bump but still looking.. Some of my displays are only 1080i and some are 1080p. I just want to write a script I can activate to set resolution to 720p and another to set it to 1080p.
Any ideas anyone? I can send JSON protocols or run scripts - either...
Thank you
http://forum.xbmc.org/showthread.php?tid...pid1684826
A list of settings that can be changed via json, looks like screen resolution is configurable.
