2014-04-14, 10:07
Hi all,
I've just installed the XBMCbuntu Beta2. I have a few questions maybe someone can help.
1) During installation I created a User. With this user I can log in via ssh on the Machine. For easier administration I wanted to log on as root and therefor created a password with
sudo passwd root
I was asked for the new Unix password, entered and then confirmed. Tried to login via ssh (or the machine itself but it does not work) I tried it for several times but noway. Is there any specialty that this does not work? I have a second Linux System for testing (with Ubuntu 13.10 Saucy) and there I have no problems
2) XBMC does start at the beginning. This is very easy but where exactly is that triggered. Is there a start up script where possibly I could enter some more stuff to start. Or is there a special Post start scrip for that. I wanted to activate e.g. a hotspot and have to start several services for that
3) Do you recommend an kernel update to 3.14? I use an Intel Haswell NUC.
Thanks a lot
Alex
sudo passwd root
Thanks a lot
Alex
