Full Version: Left side menu access in EPG (most skins)
I'm using Gotham Beta 3, ArgusTV for live TV on a Windows 8 system with an IR remote.
This may be a daft question, but within TV, when you're looking at the EPG, how do you get back to the left-side menu to access radio stations and other views. Pressing the usual 'left' just scrolls backwards through the EPG. Eventually you hit the 'start' of the EPG and the side menu pops out, but there must be a neater way. I've tried mashing all sorts of buttons to get it to come up!
Am I missing something obvious? This has been seen in Confluence and Transparency.
Oh, and how do you get genre colours to come up...can't see the option to turn it on anywhere...
The "sideblade" is mapped to back button in latest Gotham builds
Really...two seconds...
...nope, just takes me back to the home screen...that's Transparency...will try Confluence...
...works fine there. Skin issue, I'll post in the Transparency forum.
The genre colors are set by the PVR addon, if it doesn't support them all you get is grey.
OK...thanks. Doesn't look like Argus TV does it. Still, rather have stability than pretty colours.
