2014-04-15, 16:37
2014-04-15, 16:39
The Hobbit The Desolation Of Smaug (2013).cd1
The Hobbit The Desolation Of Smaug (2013).cd2
2014-04-15, 16:52
It are bluray folder map structures..
2014-04-15, 17:30
Oh i assumed they were ISO files.
I have the same files but in 3D ISO. CD1 & CD2 naming convention worked
http://i.imgur.com/TwhfZbl.jpg
2014-04-15, 17:48
Does it autoplay the 2 discs after eachother?
And both discs are behind that cover?
Since its iso i assume its mvc format? You use an external player then for them to play?
2014-04-15, 18:13
Yes xbmc will autoplay after each other
I also have two parts of hobbit 1 in 2D and used this same naming. Xbmc played both files after each other.
I use TMT6 external player to launch 3D ISO(mvc) only. For 2D Iso files I use default xbmc player
2014-04-15, 20:56
K.. Then i only wonder how to do it with bluray bdmv folder instead of one iso file?
2014-04-15, 23:03
If you tried naming each folder to end with .cd1, cd2 and that does not work. You have two options:
Convert bdmv to iso with imgburn -- If you're interested in bd menu
Convert bdmv to MKV with MakeMKV -- If you're only interested the movie
2014-04-27, 18:25
(2014-04-15, 23:03)tboggie Wrote: [ -> ]If you tried naming each folder to end with .cd1, cd2 and that does not work. You have two options:
im trying to do convert bdmv to iso, with imgburn
i installed imgburn
now how do i proceed
i've chosen "create iso file from files/folder"
then what?
i add the folders bdmv and certificate?
or do i add "desolation of smaug" which contains the fodlers bdmv and certificate and the files within?
