(2014-10-01, 18:12)Unfledged Wrote: [ -> ]If you still have it, any chance you could give me a full copy of that log - via PM's fine so as not to derail this thread. That's an issue with my script, not Conq specifically.
Sure, here's the
full log although it isn't a debug log.
To explain what I did: I installed Conq from Hitchers 5.0 repo, switched to the Conq skin in Settings -> Appearance, then when I exited from Settings it said something about "building menu" and that's when the error appeared in the log. I don't seem to be able to reproduce it, so it may just be a first-run kind of problem.
(2014-10-01, 18:21)Milhouse Wrote: [ -> ] (2014-10-01, 18:12)Unfledged Wrote: [ -> ]If you still have it, any chance you could give me a full copy of that log - via PM's fine so as not to derail this thread. That's an issue with my script, not Conq specifically.
Sure, here's the full log although it isn't a debug log.
Yup, first-run issue. I forget sometimes I still have legacy code (in early builds - which used Gotham list-filling methods - speed was paramount, and (on most systems) it was quicker to try to read a file and fail then handle the error, than bother checking if the file exists). I really must change that
. Thanks for the log, though
New OpenELEC Helix build:
#1001
(Supercedes previous build)
# uname -a
Linux rpi512 3.16.3 #1 PREEMPT Wed Oct 1 23:49:51 BST 2014 armv6l GNU/Linux
# vcgencmd version
Oct 1 2014 22:37:42
Copyright (c) 2012 Broadcom
version 93c98148caed4bc6e4a741944c2717318874e387 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141001234843-r19316-gc54bd52 [Build #1001]
Based on tip of
OpenELEC master (c54bd52f,
changelog) and tip of
XBMC master (28d47e3f,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.16.y
- Excludes the OpenELEC xbmc-001-newclock4 patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
- Default setting for "Show RSS Feed" changed to disabled
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Adapted service.openelec.settings to take advantage of PR5217
- Includes latest libnfs master (ab1af695)
- Includes latest libcec master (81e38211)
- Includes latest xbmc-pvr-addons master (83ee302d)
- Includes latest xbmc-addon-xvdr master (a3724213)
- Includes libcec double-key suppression
- Includes libcec CEC Standby Fix
- Increase scan interval of PeripBusCEC from 5000 to 60000, reducing CPU loading by about 2% (1GHz Pi) every 5 seconds (even when CEC is "disabled")
- Includes CONFIG_COREDUMP=y to allow creation of coredumps (see here)
- Includes PR5204: [Fix] Make ext. subtitle loading work for image files and bluray directories
- Includes PR5222: videodb: Add column name on GROUP query otherwise sub query returns no rows
- Includes PR5247: StringUtils: optimize Split(), new overloads for Split() and Tokenize()
- Includes PR5309: [posix] Implement new PosixFile
- Includes PR5312: dvdplayer: do a seek after having changed subtitle stream
- Includes PR5324: Add setting to hide library clean progress bar.
- Includes PR5386: Fix incorrect usage of S_IFDIR flag
- Includes PR5395: [fix] Closes #15423 Addon update deadlock due to race condition deleting CThread
- Includes PR5431: [videodb] Fix MySQL error while cleaning tvshows
Build Highlights:
- New firmware with deinterlace fixes
- Deinterlace method (Bob, Deinterlace, Deinterlace Half) now selectable in Video OSD
- @Memphiz iOS8 AirPlay fixes removed from newclock4, replaced by alternative @DBMandrake fix - please test and post feedback in the iOS8 AirPlay thread
Build Details:
- Firmware (Oct 1):
- firmware: deinterlace: Fix for garbage in bottom row of non-32-aligned height.
- firmware: deinterlace: support half framerate variants.
- firmware: mmal: allow user flags to be passed through to omx and returned
- OpenELEC:
- libva: update to libva-1.4.0
- libva-intel-driver: update to libva-intel-driver-1.4.0
- libtirpc: update to libtirpc-0.2.5
- projects/*/linux: add Pantherlord game controller support, this fixes #3518
- path: fix folders returned by find command (PR:3510, 1 commit, 2 files changed)
- xbmc: make binary addons executable after installation (PR:3505, 1 commit, 1 file changed)
- XBMC:
- fix wrong printf format mismatches (PR:5408, 1 commit, 33 files changed)
- newclock4:
- [mmalcodec] squash: Avoid preroll when using trickplay
- [airplay] Try DBMandrake's simple iOS8 scheme
- mmal: squash: Tidy deinterlace features
- mmalcodec: squash: Use USER flag to indentify deinterlaced frames
- [dvdplayer] Remove omx render features from dvdplayer and handle in mmalrenderer
- [mmalrenderer] Add choice of 3 deinterlace schemes
Popcornmix i see that you reverted "hack: revert squash: don't update originaldts when marked as invalid", and now when there is a glitch in video it takes very long to resume and once it resumes it is like in slow motion once again. Anyway i updated to latest build and enabled dump out audio/video data.. here is a link to zip file containing relevant files
https://dl.dropboxusercontent.com/u/5174...0Debug.zip . the behavior observed is that video/audio freeze for over 1 minute and then resume but are not smooth and sound is like breaking up. If i revert to the older build (29th) video audio resume correctly a couple of seconds after glitch..
(2014-10-01, 17:43)Milhouse Wrote: [ -> ] (2014-10-01, 16:07)steve1977 Wrote: [ -> ]Any idea about my Conq skin issue?
Look in your xbmc.log for errors. I just installed Conq and see the following errors:
16:20:27 64882.558594 T:3058716672 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/blue.jpg not found
16:20:27 64882.558594 T:3058716672 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/blue.jpg
16:20:29 64884.359375 T:3058716672 ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/blue.jpg not found
16:20:29 64884.359375 T:3058716672 NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/blue.jpg
Thanks for your reply. I have reached out to the Conq developer. He is a great guy and am sure he will fix this soon.
(2014-10-01, 12:09)popcornmix Wrote: [ -> ]You can see the orientation flags using identify (from imagemagick)
$ identify -verbose flipped-rpi.jpg |grep -i orient
Orientation: TopLeft
exif:Orientation: 1
So it looks like this one doesn't have a flipped flag, but probably should.
It may take a bit of digging to work out how the flip flag should get from GUI to jpeg re-encode function, but I'll add it to the list.
Now I'm not completely sure if this actually worked in newclock3. As it's working under OS X, I've only looked at xbmc/cores/omxplayer/OMXImage.* (in master) - no recent commits there seem to indicate anything related to image orientation or EXIF at all. These files are unchanged in newclock4, except a log line.
#1002
# uname -a
Linux rpi512 3.16.3 #1 PREEMPT Fri Oct 3 03:31:32 BST 2014 armv6l GNU/Linux
# vcgencmd version
Oct 1 2014 22:37:42
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141003033024-r19322-gdded97b [Build #1002]
Based on tip of
OpenELEC master (dded97b4,
XBMC master (70ad1dad,
Build Highlights:
- Bump to 14-Alpha5
- Drop PR5204
Build Details:
- OpenELEC:
- pcre: update to pcre-8.36
- xf86-video-ati: update to xf86-video-ati-7.5.0
- media_build: update drivers to version 2014-08-15
- media_build: update drivers to version 2014-09-03
- media_build: update drivers to version 2014-09-26
- ncurses: enable installing curses.h
- XBMC:
- Fix wrongly used CFile::Exists() for directories instead of CDirectory::Exists() (PR:5349, 1 commit, 6 files changed)
- [win32/nsis/rebrand] - don't force remove former XBMC installation (PR:5412, 3 commits, 1 file changed)
- [release] bump to 14.0 alpha5 (PR:5394, 1 commit, 2 files changed)
- [win32] (Re)implement Win32SMBFile (PR:5284, 3 commits, 12 files changed)
- StringUtils: optimize Split(), new overloads for Split() and Tokenize() (PR:5247, 7 commits, 18 files changed)
- [linux] SysInfo::GetUserAgent: add name of Linux distribution like some Chrome versions do (PR:5440, 1 commit, 1 file changed)
- Update UserAgent string with brand change (PR:5384, 2 commits, 2 files changed)
Were these files usefull or do you need anything else?
(2014-10-02, 05:21)gendo Wrote: [ -> ]Popcornmix i see that you reverted "hack: revert squash: don't update originaldts when marked as invalid", and now when there is a glitch in video it takes very long to resume and once it resumes it is like in slow motion once again. Anyway i updated to latest build and enabled dump out audio/video data.. here is a link to zip file containing relevant files https://dl.dropboxusercontent.com/u/5174...0Debug.zip . the behavior observed is that video/audio freeze for over 1 minute and then resume but are not smooth and sound is like breaking up. If i revert to the older build (29th) video audio resume correctly a couple of seconds after glitch..
(2014-10-03, 08:48)gendo Wrote: [ -> ]Were these files usefull or do you need anything else?
I've downloaded the files but not had a chance to test yet.
Should do this weekend.
no hurry whatsoever.. just let me know should you need anything else or to test something.. i can pretty much reproduce at will..
(2014-10-03, 10:42)popcornmix Wrote: [ -> ] (2014-10-03, 08:48)gendo Wrote: [ -> ]Were these files usefull or do you need anything else?
#1003
# uname -a
Linux rpi512 3.16.3 #1 PREEMPT Sat Oct 4 00:19:43 BST 2014 armv6l GNU/Linux
# vcgencmd version
Oct 1 2014 22:37:42
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141004001835-r19322-gdded97b [Build #1003]
Based on tip of
XBMC master (eb258823,
Build Highlights:
- popcornmix PR5354 and PR5442 merged upstream
- Add resampling option to Acceleration settings (though a bit strange for it to be in the Video section?)
- Drop newclock4 commit: [power] hack - Make suspend toggle suspend state
Build Details:
- XBMC:
- VobSub fixes (PR:5414, 5 commits, 4 files changed)
- linuxrenderer: drop obsolete includes (PR:5432, 2 commits, 2 files changed)
- set deinterlace mode to AUTO as default (PR:5418, 1 commit, 1 file changed)
- Fix incorrect usage of S_IFDIR flag (PR:5386, 1 commit, 3 files changed)
- [pvr] fix: last watched timestamps won't update after channel switch (PR:5400, 2 commits, 7 files changed)
- [bluray] Add a setting for preferred bd playback (PR:5228, 4 commits, 9 files changed)
- [Fix] Make ext. subtitle loading work for image files and bluray directories (PR:5204, 2 commits, 3 files changed)
- compil against external libbluray (PR:4153, 1 commit, 1 file changed)
- [omxplayer] Fix bad audio when sample_fmt is not reported on Open (PR:5442, 1 commit, 1 file changed)
- [fix] Closes #15423 Addon update deadlock due to race condition deleting CThread (PR:5395, 1 commit, 1 file changed)
- [readme] update master github readme (PR:5426, 1 commit, 2 files changed)
- [mmal] Add MMAL decoder and MMAL renderer for Raspberry Pi (PR:5354, 1 commit, 17 files changed)
- [Fix] Make up missed ShowPicture in command array (PR:5404, 1 commit, 1 file changed)
- Fix: missing space for Kodi forks. Thanks to @notspiff
- Update tests for SysInfo::GetUserAgent(). Thanks @notspiff
- newclock4:
- AE: fix S24NE3
- pthreads: use mutex protocol PTHREAD_PRIO_INHERIT
- Implement PosixFile class for accessing local files on Posix platforms
- Switch to new PosixFile
- Remove HDFile
- [AE] Add factory for AEResampler
- settings: Add acceleration option for resampling
- [omxcore] Skip out of flush on error
- [SinkPi] Handle multichannel layout more like OMXAudio
- Revert "pthreads: use mutex protocol PTHREAD_PRIO_INHERIT"
- kernel 3.16.y:
- bcm2708: Add extension to configure internal pulls
- lirc_rpi: Add parameter to specify input pin pull
Here everything is working well (and fast
) besides LiveTV with tvheadend. I'm not sure if it's right to post it here but because tvheadend is working on OE 4.1 I thought it is somehow related to Helix.
When I install tvheadend from XBMC-Repo it gets installed and activated without issues. But the HTSP-client loses connection every time so I read the logs and started up tvheadend manually because it wasn't starting up automatically on boot (no clue why). Now the webfrontend was accessable but with a user and a password which I didn't know. Later I found out that it was because of missing files in /storage/.hts that are controlling the access and which weren't created while tvheadend installation (dont' ask me why). After adding muxes and scanning them nothing was found because of no data delivered by my adapter (which worked well on 4.1). The problem ocurrs for me since I switched back from official 4.1 to Milhouse-builds in mid september.
Regards Shadowghost
I'm currently experiencing stuttering in almost all videos. Stuttering lasts a few (2-7 perhaps?) seconds, and log file fills upp with lines like these during the stuttering:
DEBUG: CDVDPlayer::OMXDoProcessing Resume 3.08,0.00 (A:00 V:10) EOF:0 FULL:1 T:16.00
DEBUG: OMXClock::OMXSetSpeed(1.00) pause_resume:1
I read somewhere that this could be due to a bad network connection, but I have also tried playing a video straight from my USB drive with the same result.
I have tried changing cache settings:
<buffermode>1</buffermode>
<cachemembuffersize>0</cachemembuffersize>
<readbufferfactor>4.0</readbufferfactor>
Since I have updated a few times in the last few days, I tried going back to versions that I KNOW worked, but I'm still seeing the issue. Any ideas?
Here's a complete log file:
http://xbmclogs.com/show.php?id=309891
