(2014-10-13, 17:06)popcornmix Wrote: [ -> ] (2014-10-13, 16:36)Milhouse Wrote: [ -> ]So when the 3.17 kernel was introduced... Do you know which modules this Hauppauge remote control requires? Presumably the rest of the tuner is working ok - do you have a link that provides more details about the hardware?
Running lsmod on the working system and the not-working system might show if any kernel modules are missing.
Sorry, I have little technical knowledge, so would not know what modules are required.
The equipment is pretty old and has been mainly superceded - a bit like me
I did manage to putty into the builds so here is lsmod for both.
LSMOD FOR 1007
OpenELEC (Milhouse) Version: devel-20141007210109-r19342-gdc51895
OpenELEC git: dc51895fff5b697dcd65039365d2ceb2f926792c
OpenELEC:~ # lsmod
Module Size Used by
rc_dib0700_rc5 1982 0
arizona_ldo1 2335 0
fixed 1425 2147483647
arizona_spi 1109 0
snd_soc_wm8804 7306 0
snd_soc_bcm2708_i2s 5577 0
snd_soc_pcm512x_i2c 1481 0
snd_soc_tas5713 4760 0
snd_soc_pcm512x 6372 1 snd_soc_pcm512x_i2c
regmap_spi 1465 2 snd_soc_wm8804,arizona_spi
regmap_i2c 1974 3 snd_soc_wm8804,snd_soc_pcm512x_i2c,snd_soc_tas5713
regmap_mmio 2181 1 snd_soc_bcm2708_i2s
snd_soc_core 100943 4 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_tas5713,snd_soc_bcm2708_i2s
snd_compress 7084 1 snd_soc_core
snd_pcm_dmaengine 2927 1 snd_soc_core
snd_pcm 62712 2 snd_soc_core,snd_pcm_dmaengine
snd_timer 17660 1 snd_pcm
snd 41549 4 snd_soc_core,snd_timer,snd_pcm,snd_compress
dvb_usb_dib0700 89061 0
dib3000mc 11009 1 dvb_usb_dib0700
dib8000 46303 1 dvb_usb_dib0700
dib0070 7188 4 dvb_usb_dib0700
dib7000m 13739 1 dvb_usb_dib0700
dib0090 22757 1 dvb_usb_dib0700
dib7000p 25372 4 dvb_usb_dib0700
dibx000_common 6109 5 dib8000,dvb_usb_dib0700,dib3000mc,dib7000m,dib7000p
dvb_usb 15465 1 dvb_usb_dib0700
dvb_core 80875 3 dib8000,dvb_usb,dib7000p
lirc_rpi 6008 3
lirc_dev 7885 1 lirc_rpi
rc_core 13961 6 lirc_dev,dvb_usb,dvb_usb_dib0700,rc_dib0700_rc5
bcm2708_rng 808 0
OpenELEC:~ #
LSMOD for 1008
OpenELEC (Milhouse) Version: devel-20141009011610-r19342-gdc51895
OpenELEC:~ # lsmod
Module Size Used by
dib7000p 27661 3
arizona_ldo1 2335 0
arizona_spi 1109 0
snd_soc_bcm2708_i2s 5585 0
snd_soc_wm8804 7092 0
snd_soc_pcm512x 6356 1 snd_soc_pcm512x_i2c
snd_soc_core 104264 4 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_tas5713,snd_soc_bcm2708_i2s
snd_pcm_dmaengine 2935 1 snd_soc_core
snd_pcm 63094 3 snd_soc_wm8804,snd_soc_core,snd_pcm_dmaengine
snd_timer 17712 1 snd_pcm
dvb_usb_dib0700 90357 0
dib3000mc 10997 1 dvb_usb_dib0700
dib7000m 13719 1 dvb_usb_dib0700
dib0090 22997 1 dvb_usb_dib0700
dibx000_common 6109 4 dvb_usb_dib0700,dib3000mc,dib7000m,dib7000p
dvb_core 78549 2 dvb_usb,dib7000p
lirc_rpi 6008 3
rc_core 16223 6 lirc_dev,dvb_usb,dvb_usb_dib0700,rc_dib0700_rc5
bcm2708_rng 812 0
OpenELEC:~ #
here are best links I can find to describe hardware:
http://www.hauppauge.co.uk/site/products/data_duet.html
http://www.shop.bt.com/products/hauppaug...-42PG.html
http://www.ebay.co.uk/itm/like/111475480...0&ff14=108
hope that helps
pootler[
