(2014-10-21, 20:14)kieranc Wrote: [ -> ]FWIW, hifiberry doesn't work with #1020
Pastebin.com/P6jqJ0mZ
Thanks, unfortunately I don't know the cause, or have a solution. You'll need to contact Hifiberry and let them know there's a problem with their hardware and the 3.17.y kernel and maybe they can offer a solution - it looks like they only support OpenELEC up to v4.1.6, and Helix/OE5 with the very latest kernel may not even be on their radar (although it probably should be).
It's quite possibly a conflicting or missing kernel option (current
kernel options), but I'm sure they can work it out - sadly it's beyond my ken.
I have a iso-file, dvd-rip, with no menu. It does not start playing when it is located on my nfs or smb-share, but when I play it located on a USB-pin (ntfs) it starts playing. Others iso plays smoothly.
The log-file can be downloaded
here
Edit: Build #1018 plays it, #1019 to 1023 does not.
Edit:
I did a random check on my iso's.
build #1019 to 1023: Some but not all with no menus does not start playing. All of those I checked with menus played well.
Build #1018: all seems to play fine
New OpenELEC Helix build:
#1021
(Supercedes previous build)
# uname -a
Linux rpi512 3.17.1 #1 PREEMPT Tue Oct 21 21:02:33 BST 2014 armv6l GNU/Linux
# vcgencmd version
Oct 17 2014 17:56:05
Copyright (c) 2012 Broadcom
version 845092531e360acd37f2f1964157f8079c77edfb (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141021210121-r19445-g75e8cd3 [Build #1021]
Based on tip of
OpenELEC master (75e8cd34,
changelog) and tip of
XBMC master (96f3d33f,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.17.y
- Excludes the OpenELEC xbmc-001-newclock4 patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
- Default setting for "Show RSS Feed" changed to disabled
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Adapted service.openelec.settings to take advantage of PR5217
- Includes latest libnfs master (ab1af695)
- Includes latest libcec master (81e38211)
- Includes latest xbmc-pvr-addons master (067befe6)
- Includes latest xbmc-addon-xvdr master (2bf2563c)
- Includes libcec double-key suppression
- Includes libcec CEC Standby Fix
- Increase scan interval of PeripBusCEC from 5000 to 60000, reducing CPU loading by about 2% (1GHz Pi) every 5 seconds (even when CEC is "disabled")
- Includes CONFIG_COREDUMP=y to allow creation of coredumps (see here)
- Includes additional ffmpeg codecs/muxers enabled for testing/benchmarking purposes. See patch
- Includes PR:5312: dvdplayer: do a seek after having changed subtitle stream
- Includes PR:5416: added: POC mp4 movie/episode tag support
- Includes PR:5524: Respect parent path decision when cleaning paths.
Build Highlights:
- OpenELEC Kodi rebranding
- Updated xbmc-pvr-addons master (changelog)
Build Details:
- OpenELEC:
- [xbmc-rebrand] xbmc: move to package 'kodi'
- [xbmc-rebrand] xbmc-theme-Confluence: move to package 'kodi-theme-Confluence'
- [xbmc-rebrand] xbmc-audioencoder-flac: move to package 'kodi-audioencoder-flac'
- [xbmc-rebrand] xbmc-audioencoder-lame: move to package 'kodi-audioencoder-lame'
- [xbmc-rebrand] xbmc-audioencoder-vorbis: move to package 'kodi-audioencoder-vorbis'
- [xbmc-rebrand] xbmc-audioencoder-wav: move to package 'kodi-audioencoder-wav'
- [xbmc-rebrand] xbmc-addon-xvdr: move to package 'kodi-addon-xvdr'
- [xbmc-rebrand] xbmc-pvr-addons: move to package 'kodi-pvr-addons'
- [xbmc-rebrand] mediacenter: move package depends
- kodi-audioencoder-flac: update to kodi-audioencoder-flac-84bdf32
- kodi-audioencoder-lame: update to kodi-audioencoder-lame-90fb99b
- kodi-audioencoder-vorbis: update to kodi-audioencoder-vorbis-a73ef7e
- kodi-audioencoder-wav: update to kodi-audioencoder-wav-b28ab95
- kodi-pvr-addons: update to kodi-pvr-addons-067befe
- linux: add upstream patch
- [xbmc-rebrand] scripts/image: rename XBMC comments to 'Kodi'
- [xbmc-rebrand] config/functions: rename XBMC comments to 'Kodi'
- XBMC:
- dxva: fix selection of render target format (PR:5531, 1 commit, 1 file changed)
- [win32] fix running XBMC with custom home directory (PR:5542, 2 commits, 2 files changed)
- Confluence fixes (PR:5546, 3 commits, 2 files changed)
- [pvr] fix toggle between previous and next channel (PR:5528, 2 commits, 3 files changed)
- [rebrand] - fixed some labels from strings.po files (PR:5548, 1 commit, 1 file changed)
hi there, since version #1020 and #1021 the addon openelecdevupdate stop working, this is my log
05:21:53 47201.980469 T:2675962960 NOTICE: -->Python Interpreter Initialized<--
05:21:53 47202.234375 T:2675962960 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named bs4
File "/storage/.xbmc/addons/script.openelec.devupdate/service.py", line 12, in <module>
from resources.lib import builds
File "/storage/.xbmc/addons/script.openelec.devupdate/resources/lib/builds.py", line 10, in <module>
from bs4 import BeautifulSoup, SoupStrainer
ImportError: No module named bs4
maybe you can fix this...
rgds
(2014-10-22, 09:42)platin Wrote: [ -> ]hi there, since version #1020 and #1021 the addon openelecdevupdate stop working, this is my log
rgds
Can you upload a full debug log to xbmclogs.com and post the link. It seems like a problem with the python path, so probably not an issue with the add-on itself.
(2014-10-22, 12:08)platin Wrote: [ -> ]here´s my log http://xbmclogs.com/show.php?id=324451
That's not a debug log, plus it's a log from #1019 when you say the problem starts with #1020/#1021. Please upload a full debug log from #1021, and include the error when calling the addon.
(2014-10-22, 12:23)platin Wrote: [ -> ]this is very weird, iam with #1021 and after i send the log it still on #1019
After the rebranding, the log is now called kodi.log (from #1020/#1021 onwards) - you're uploading your old log from #1019 which is when the log was last called xbmc.log. Maybe there needs to be a symbolic link from xbmc.log to kodi.log.
I've just installed the OpenELEC Dev Update addon from
github (sha:9b1d605e, install from zip) and configured it to use my folder as the Source URL (ie. "MilhouseVH Builds (RPI)") with everything else left as default, and it fails while looking for "/usr/lib/xbmc/xbmc.bin" which no longer exists (it''s now "/usr/lib/kodi/kodi.bin").
Haven't been able to reproduce any BS4 failure.
Debug log:
http://sprunge.us/hCLO
ok, thanks for your support my previous post has the right log from kodi
(2014-10-21, 20:29)Milhouse Wrote: [ -> ] (2014-10-21, 20:14)kieranc Wrote: [ -> ]FWIW, hifiberry doesn't work with #1020
It's quite possibly a conflicting or missing kernel option (current kernel options), but I'm sure they can work it out - sadly it's beyond my ken.
Well, I've tried speaking to the hifiberry devs (dev?) but he seems unwilling to accept that it's a problem, or his problem.
Can anyone speculate as to when 3.17 is likely to be used on a general-release openelec build? Days, weeks months?
(2014-10-22, 17:09)kieranc Wrote: [ -> ]Well, I've tried speaking to the hifiberry devs (dev?) but he seems unwilling to accept that it's a problem, or his problem.
The Helix OE stable release will be on at least 3.17.
Hard to say exactly when that will happen, but I think by the end of the year is the approximate timescale.
That's an unfortunate response, to put it mildly. Glad I haven't invested any money with that company.
Does anyone have problems with subtitles? Here videos stutter every 20-30 seconds.
