hi,
maybe stupid question, but is any possibility to get work webgrabplus?
(2014-10-22, 19:07)paulyz Wrote: [ -> ]hi,
See "Feature Requests" section in the first post.
Edit: I meant
this post not the
first thread.
ok ok, I understand
If you want - do by yourself
(2014-10-22, 17:52)slack3r Wrote: [ -> ]Does anyone have problems with subtitles? Here videos stutter every 20-30 seconds.
I had problems with <1019 builds (didn't test all), but with #1019 they are gone. Will report back, if they show up again.
(2014-10-22, 12:38)Milhouse Wrote: [ -> ] (2014-10-22, 12:23)platin Wrote: [ -> ]this is very weird, iam with #1021 and after i send the log it still on #1019
After the rebranding, the log is now called kodi.log (from #1020/#1021 onwards) - you're uploading your old log from #1019 which is when the log was last called xbmc.log. Maybe there needs to be a symbolic link from xbmc.log to kodi.log.
I've just installed the OpenELEC Dev Update addon from github (sha:9b1d605e, install from zip) and configured it to use my folder as the Source URL (ie. "MilhouseVH Builds (RPI)") with everything else left as default, and it fails while looking for "/usr/lib/xbmc/xbmc.bin" which no longer exists (it''s now "/usr/lib/kodi/kodi.bin").
Haven't been able to reproduce any BS4 failure.
Debug log: http://sprunge.us/hCLO
Thanks for the log. I've now fixed this problem.
New OpenELEC Helix build:
#1022
(Supercedes previous build)
# uname -a
Linux rpi512 3.17.1 #1 PREEMPT Wed Oct 22 21:03:54 BST 2014 armv6l GNU/Linux
# vcgencmd version
Oct 17 2014 17:56:05
Copyright (c) 2012 Broadcom
version 845092531e360acd37f2f1964157f8079c77edfb (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141022210241-r19452-g0858c78 [Build #1022]
Based on tip of
OpenELEC master (0858c78a,
changelog) and tip of
XBMC master (94636baf,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.17.y
- Excludes the OpenELEC xbmc-001-newclock4 patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
- Default setting for "Show RSS Feed" changed to disabled
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Adapted service.openelec.settings to take advantage of PR5217
- Includes latest libnfs master (ab1af695)
- Includes latest libcec master (81e38211)
- Includes latest xbmc-pvr-addons master (067befe6)
- Includes latest xbmc-addon-xvdr master (2bf2563c)
- Includes libcec double-key suppression
- Includes libcec CEC Standby Fix
- Increase scan interval of PeripBusCEC from 5000 to 60000, reducing CPU loading by about 2% (1GHz Pi) every 5 seconds (even when CEC is "disabled")
- Includes CONFIG_COREDUMP=y to allow creation of coredumps (see here)
- Includes additional ffmpeg codecs/muxers enabled for testing/benchmarking purposes. See patch
- Includes PR:5312: dvdplayer: do a seek after having changed subtitle stream
- Includes PR:5416: added: POC mp4 movie/episode tag support
- Includes PR:5524: Respect parent path decision when cleaning paths.
Build Highlights:
- vdr-plugin-vnsiserver bump
- Allow player to retry read in case of read errors
Build Details:
- OpenELEC:
- service.openelec.settings: update to service.openelec.settings-0.4.4
- service.openelec.settings: update to service.openelec.settings-0.4.5
- scripts/image: add ARCH= and BUILD= to /etc/os-release
- scripts/image: prefix OpenELEC own variables with OPENELEC_ in /etc/os-release
- vdr-plugin-vnsiserver: update to vdr-plugin-vnsiserver-a7cb405
- vdr-addon: update changelog
- vdr-addon: bump addon version to 4.3.1
- XBMC:
- dxva: fix memory leak caused by additional ref on video surfaces (PR:5541, 1 commit, 1 file changed)
- [pvr] bump add-ons (PR:5544, 1 commit, 2 files changed)
- Allow player to retry read in case of read errors (PR:5537, 2 commits, 3 files changed)
- Fix gtests after rebrand (PR:5552, 2 commits, 3 files changed)
- [pvr] fix unnecessary creation of new CPVRChannel instances (PR:5473, 1 commit, 1 file changed)
- [pvr] fix continue playback of last watched channel on startup if group was deleted or channel was moved (PR:5526, 1 commit, 5 files changed)
- [pvr] fix call to base class GetContextButtons() to re-add favorite entry (PR:5547, 1 commit, 5 files changed)
- [git] - add generated FEH-ARM.py and FEH.py to gitignore
- [osx] - don't release strings we didn't alloc - fixes crash on shutdown (introduced in rebrand)
- [buildsteps] fix linux32 gtests invocation as well
(2014-10-23, 12:28)popcornmix Wrote: [ -> ]Always post the complete log. Don't cut it down.
Ok. I will do it asap, thank you.
P.s.
Build #1004 seems running fine.
(2014-10-23, 14:38)slack3r Wrote: [ -> ]Attached:
http://pastebin.com/q5AMwHhL
I suspect these are important:
14:17:05 399.017242 T:2729636944 ERROR: CCurlFile::FillBuffer - Failed: Failure when receiving data from the peer(56)
14:17:05 399.017944 T:2729636944 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
but there's not much info there. Enabling component specific debugging and enabling curl may give more info.
Also you say #1004 is good and #1022 is bad - can you identify the exact build that started the problem.
That may indicate an updated library or a pull request that caused the problem.
(2014-10-23, 14:43)popcornmix Wrote: [ -> ]I suspect these are important:
I will post it asap. Thank you very much.
Quote:Also you say #1004 is good and #1022 is bad - can you identify the exact build that started the problem.
I think the issue occurs between #1004 and #1007, but I'm not sure. I'll let you know.
