(2014-11-13, 15:44)popcornmix Wrote: [ -> ] (2014-11-13, 13:58)sdsnyr94 Wrote: [ -> ]I'll test tonight to see if this helps my issue... does this affect dvdplayer only (leave omxplayer off)?
This is common code, so will affect omxplayer and dvdplayer.
I was only able to do a quick test, but after about 10 minutes the Audio/Video were still in sync (normally it would be out of sync within a minute or 2). I'll have a chance to test more Saturday, when I have time to watch a full game.
(2014-11-14, 00:17)Milhouse Wrote: [ -> ]Removed "CONFIG_REGULATOR=y" from linux.arm.conf to see if this helps fix Hifiberry hardware (please test, Hifiberry users)
YAY! My Digi works perfectly again
(2014-11-14, 21:23)slomovizion Wrote: [ -> ] (2014-11-14, 00:17)Milhouse Wrote: [ -> ]Removed "CONFIG_REGULATOR=y" from linux.arm.conf to see if this helps fix Hifiberry hardware (please test, Hifiberry users)
Yes, also for me having a Digi on Raspi B build #1113 is running perfectly! Thank you very very much for the fix!
regards
What does your hifiberry.conf look like?
(2014-11-14, 22:59)ijsbeer79 Wrote: [ -> ]What does your hifiberry.conf look like?
like before with the modules
snd_soc_bcm2708_i2s
bcm2708_dmaengine
snd_soc_wm8804
snd_soc_hifiberry_digi
New OpenELEC Helix build:
#1114
(Supercedes previous build)
# uname -a
Linux rpi512 3.17.2 #1 PREEMPT Fri Nov 14 21:11:27 GMT 2014 armv6l GNU/Linux
# vcgencmd version
Nov 7 2014 17:01:00
Copyright (c) 2012 Broadcom
version 3bd41a132583ec90e4a0410a4aa631d1e4e2d8ea (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141114211018-r19633-g917fa5f [Build #1114]
Based on tip of
OpenELEC master (917fa5f4,
changelog) and tip of
XBMC master (19893f87,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.17.y
- Excludes the OpenELEC xbmc-001-newclock4 patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Adapted service.openelec.settings to take advantage of PR:5217 [patch details]
- Includes latest libnfs master (4a58e614)
- Includes latest libcec master (70e1b5de)
- Includes latest xbmc-pvr-addons master (06842b90)
- Includes latest xbmc-addon-xvdr master (328fa653)
- Includes CONFIG_COREDUMP=y to allow creation of coredumps (see here)
- Includes additional ffmpeg codecs/muxers enabled for testing/benchmarking purposes (see patch)
- Includes commits from libcec-2.2.0 (popcornmix)
- Includes PR:5573: webserver: improved caching control (see discussion)
- Includes PR:5700: [WIP] Fix for libdvdcss partial read
- Includes PR:5707: Even better emulate POSIX file functions (reduced)
- Includes PR:5713: Fix "Current fanart" not being shown in DialogVideoInfo.
Build Highlights:
- HifiBerry confirmed working, CONFIG_REGULATOR dropped upstream
- [omxcodec] Don't force software codec with dvds
Build Details:
- OpenELEC:
- v4l-utils: fix rc6_mce mapfile (67d30ac1)
- dbus: update to dbus-1.8.10 (501619f3)
- linux: add upstream patch (230295be)
- projects/*/linux: disable CONFIG_REGULATOR, this fixes #3617 (917fa5f4)
- XBMC:
- [pvr] bump addons (PR:5715, 1 commit, 2 files changed)
- Coverity: Fixes 2 (PR:5711, 5 commits, 10 files changed)
- [epg] rename GetCurrentTime() to avoid naming collision with Windows-specific macro (PR:5726, 1 commit, 2 files changed)
- [cosmetics] minor spacing in readme (PR:5724, 1 commit, 1 file changed)
- AE: always request float from sink when in fixed mode, fixes unwanted re... (PR:5718, 1 commit, 1 file changed)
- [darwin] - fix flicker in sysinfo - querying gateway via pipe needs a sleep (PR:5728, 1 commit, 1 file changed)
- newclock4:
- New commits in this build:
- [omxcodec] Don't force software codec with dvds (c60186bb)
- [dvdplayervideo] Make variables more local (ad2e59e9)
- [dvdplayervideo] Move packet handling into separate function (72743cb3)
- [dvdplayervideo] Prod decoder when in stills mode (fceab269)
- Commits no longer in build:
- [omxcodec] Fix for stills with hardware codec (072bc273)
- AE: always request float from sink when in fixed mode, fixes unwanted re-init of sink (a5216bb3)
- kernel 3.17.y:
- config: Remove CONFIG_REGULATOR - we don't have a regulator driver (8605f6d9)
(2014-11-15, 07:03)Mister XY Wrote: [ -> ]@popcornmix i have great news, since new version, my Special DVD Crashed and restart Kodi. In older version, it's hang and now, the DVD reboot Kodi.
here is the Log.
http://pastebin.com/QT4MjG6u
A restart suggests a segfault which often leaves very little information in the debug log.
What's normally required is a backtrace which you should be able to obtain by following the instructions in item #3 in the first post of this thread (just don't use a debug build, use your current non-debug build and ignore the 300MB requirement - the backtrace will be incomplete, but still better than nothing).
Or upload a sample file.
Edit: I can reproduce a crash with my test DVD ISO over SMB or NFS - it happens when I navigate within the menu (select a menu item => crash).
gdb (non-debug) backtrace from #1114:
Reading symbols from /usr/lib/kodi/kodi.bin...(no debugging symbols found)...done.
Starting program: /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
Cannot access memory at address 0x0
warning: Unable to find libthread_db matching inferior's thread library, thread debugging will not be available.
[New LWP 23681]
[New LWP 23718]
[New LWP 23706]
[New LWP 23712]
[New LWP 23715]
[New LWP 23709]
[New LWP 23729]
hwclock: can't open '/dev/misc/rtc': No such file or directory
[New LWP 23756]
[New LWP 23762]
[New LWP 23764]
Program received signal SIGSEGV, Segmentation fault.
[Switching to LWP 23764]
0x00834cec in CDVDPlayerVideo::HandleDemuxerPacket(DemuxPacket*, bool, int&, double&, CDVDMsg*, DVDVideoPicture&) ()
(gdb) bt
#0 0x00834cec in CDVDPlayerVideo::HandleDemuxerPacket(DemuxPacket*, bool, int&, double&, CDVDMsg*, DVDVideoPicture&) ()
#1 0x00000000 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Build #1113 does not crash and navigates the menu without a problem. Cannot reproduce the above crash in Kodi master on Ubuntu, so looks Pi specific.
popcornmix if you need the backtrace from a debug build, let me know...
(2014-11-14, 23:12)thent Wrote: [ -> ] (2014-11-14, 22:59)ijsbeer79 Wrote: [ -> ]What does your hifiberry.conf look like?
snd_soc_bcm2708_i2s
bcm2708_dmaengine
snd_soc_wm8804
I can't speak for the digi but with the DAC+ I only needed to load "snd_soc_hifiberry_dacplus" in hifiberry.conf. bcm2708_dmaengine doesn't exist any more and generates an error on boot if you try to load it.
(2014-11-15, 07:14)Milhouse Wrote: [ -> ]Edit: I can reproduce a crash with my test DVD ISO over SMB or NFS - it happens when I navigate within the menu (select a menu item => crash).
Yes, I could reproduce this. I've pushed a fix.
(2014-11-15, 12:41)kieranc Wrote: [ -> ]I can't speak for the digi but with the DAC+ I only needed to load "snd_soc_hifiberry_dacplus" in hifiberry.conf. bcm2708_dmaengine doesn't exist any more and generates an error on boot if you try to load it.
I can confirm this for the Digi, thank you!
One issue I've got with the latest builds #1113 and #1114 is that I cannot mount samba shares to /storage/folder anymore. I'm using the "old method" with autostart.sh containing commands like:
#!/bin/sh
(sleep 30; \
mkdir /storage/folder; \
mount -t cifs -o username=username,password=password,rw //192.168.1.254/folder /storage/folder; \
Are there any logs where potentially failed mounts are logged?
Thanks,
thent
Just try mounting your cifs share at the command line, what error do you see?
#1115
# uname -a
Linux rpi512 3.17.3 #1 PREEMPT Sat Nov 15 22:28:34 GMT 2014 armv6l GNU/Linux
# vcgencmd version
Nov 7 2014 17:01:00
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141115222725-r19639-g80e4028 [Build #1115]
Based on tip of
OpenELEC master (80e4028d,
XBMC master (b3c20a2a,
- Included PR:3623: Tweaks for setting make's -j option
Build Highlights:
- New firmware.
- New 3.17.3 kernel.
- Fix for DVD menu crash (tested, works here - many thanks!)
Build Details:
- Firmware (Nov 7):
- firmware: audio_mixer: Fix typo that stops OMX_IndexParamBrcmTimeScale from working
- firmware: hdmi: Show more precision of hdmi pll setting
- OpenELEC:
- hdhomerun: allow running scripts from addon settings (PR:3622, 1 commit, 6 files changed)
- sundtek-mediatv: allow running scripts from addon settings (PR:3621, 1 commit, 11 files changed)
- linux: update to linux-3.17.3 (9365f7e3)
- ffmpeg: cosmetics (e275c974)
- XBMC:
- AESinkPULSE: Rebrand pulseaudio sink name to reflect kodi (PR:5719, 1 commit, 1 file changed)
- [buttontranslator] fix keymap overrides not working (PR:5712, 2 commits, 1 file changed)
- dvdplayer: vaapi, vdpau - implement codec control flags (PR:5710, 1 commit, 2 files changed)
- dvdplayer: fix dts correction, again (PR:5709, 1 commit, 2 files changed)
- dvdplayer: avoid short screen flicker caused by unnecessary reconfigure ... (PR:5696, 1 commit, 1 file changed)
- [rbp] Enable optimization on Raspberry Pi (PR:5677, 1 commit, 1 file changed)
- [rtmp] fix crash on seek on live streams (PR:5693, 1 commit, 2 files changed)
- Ukr and Rus language fixes (PR:5683, 1 commit, 3 files changed)
- [mmalrenderer] Add choice of 3 deinterlace schemes (PR:5626, 1 commit, 9 files changed)
- [keymap] Fix PS3 dualshock for SDL2 (PR:5637, 1 commit, 1 file changed)
- videorefclock: use videosync DRM on AMD systems (PR:5716, 1 commit, 1 file changed)
- dvdplayer: fix rewind (PR:5714, 2 commits, 5 files changed)
- Fix suspend with upowerd >= 0.99.1 (PR:5651, 1 commit, 1 file changed)
- [ResamplePi] Add support for formats that need shifting (PR:5731, 1 commit, 2 files changed)
- [pvr] add missing call to parent's OnPrepareFileItems() (PR:5730, 1 commit, 1 file changed)
- [lang] fix invalid or wrong language names to be in sync with Transifex (0ccc7e7f)
- newclock4:
- squash: stills: avoid deferencing null packet (bc2e08ea)
- [dvdplayer] Add lock for player creation (eb77209e)
- [omxplayer] Fix for out of sync after trickplay (b40f2d0a)
- hack: revert squash: don't update originaldts when marked as invalid (a6f0ed54)
- [mmalrenderer] Add choice of 4 deinterlace schemes (b7f3eec8)
- Revert "hack: revert squash: don't update originaldts when marked as invalid" (65effc02)
- [DVDMessageQueue] Remove pi specific logging ifdef (ea28b1a2)
- [ResamplePi] Add support for formats that need shifting (c6e842bc)
- add canseek and drop unused rtmp options (e26404c3)
- dvdplayer: avoid short screen flicker caused by unnecessary reconfigure of renderer (4e8aa1bc)
- dvdplayer: allow rewinding at end of stream, do a seek after rewind (47cba84d)
- dvdplayer: fix dts correction, again (ba4088a6)
- player: fix rewind (a8d33f28)
- kernel 3.17.y:
- snd-bcm2708: Fix dmesg spam for non-error case (588b0839)
- config: remove CONFIG_DEBUG_INFO (1f6cd09d)
- Additional commits/pull requests not yet merged upstream:
