Full Version: Fixed position in grouplist
I am trying to find a way to mockup a grouplist to function with a fixed focus position.
I have thus far been successful using animation sets to achieve the movement through the list, however any controls that would have extended beyond the page break are discarded.
It seems as though if it's past the page break, it cannot be directly manipulated by a slide.
Is there a known work around or is there a better way to achieve my desired outcome? Thanks!
You need to include animations for all possible positions including those outside the page.
Thanks for replying Hitcher,
I've confirmed I did have animations for each of the list items moving to positions that would have been both on and off of the page area.
My current work around is to basically "stack" all of the items just off of the visible area of the page, and bring them in. It seems like a bit of a greasy hack though as I'm sure there's a way to correctly use the grouplist controls motion to do this.
