Full Version: Accessing left-side menu from EPG
Using Gotham Beta 3.
When you're in the EPG, how can you quickly get at the left-side 'blade' menu? At the moment, the only way I can figure it out is by scrolling all the way to left of the EPG, then the blade appears allowing access to recordings, radio and so on.
In Confluence I note that hitting the 'Back' button on the remote works for this, but in T! that just takes you to the home screen.
