Full Version: linux on Jynxbox Android HD
trying to download Linux A7 RC3
trying to use linux xbmc to my Jynxbox Android HD
install Geeksquad8Linux but the remote controls not working
can someone help me out
Save this file to the root of a microSD card.
1) unplug the jynx android.
2) using a paper clip press the button on the bottom of the jynx android...
3) while the little button is pressed plug it back in.
4) wait till you see a blue light to release the button... (this will boot it in upgrade mode)
5) press upgrade... select sdcard... select and press update.img
6) allow upgrade to take place you should see upgrade successful when it's done, if not you will see upgrade fail... (this could be from a bad or the wrong img file)
7) select reboot and allow the machine to reboot
8) first boot should take longer than usual (up to 15-20min)
Installing Linux version of XBMC will completely remove Android OS from your Box.
where & how can l download New Linux Firmware a7 rc3 unlocked Image for Jynxbox Android HD
see if that work thanks sonny allso new to this
