2015-08-01, 16:02
Thanks @DarkAngel2401
I don't know how can I build this, if you send me instructions, I will try.
The testbuilds are located at: http://forum.kodi.tv/showthread.php?tid=231092
The latest one now is build #0731, located at: http://forum.kodi.tv/showthread.php?tid=...pid2068218
Can you please look at this, how can your patch be added to the build #0731? It would be great to know that I could do it myself, since these builds are released quite frequently, and then I could build the never ones myself, and could post it here if somebody needs it.
These testbuilds are so good, I'm using one atm, they are working perfectly, sure there are some bugs, but the work done compared to the stable versions is enormous, deinterlacing is brilliant!
