Full Version: [Project] Dual Audio Output support (Krypton/Jarvis/Isengard/Helix/Gotham/Frodo)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
(2015-08-23, 17:45)curtis-r Wrote: [ -> ]Is there any support for Isengard?
If you mean 'software', yes: take a look at the signature in the message of DarkAngel2401 (developer).
(2015-08-23, 22:38)getafix Wrote: [ -> ]Is there anything on the PC side that needs to be configured for dual output.
Take a look at the first post: 2 outputs to be configured. Depends on the capabilities of your hardware. Just give it a try to play around yourself, not much harm can be done.
I have downloaded the Windows Helix file and copied and overwrote the Kodi.exe and system file/folder.
Now I get a python27.dll error when trying to run Kodi.
Any ideas how I can resolve it?
I'm stick rocking Gotham, and just discovered your mod. Man, I wish I discovered this years ago!!! This is exactly what I was looking for. Throughout my home I have multiple flat panel TVs, a projector, and analog multi-zone audio, and the very best I was able to do (even utilizing some external hardware) was to have 2 xbmc profiles. This mod has eliminated the external hardware and the additional profile. My family and yours-truly-in-house-IT support thanks developers a bunch.
Update, I had to download Helix 14.2 and use the patch. Works like a charm. Now I can connect Kodi to my HDMi matrix and watch in another lounge.
Awesome work.
OpenELEC 6.0 beta 4 (based on Kodi 15.1) with Dual Audio support is available.
_____________________
Edit: All OE builds done.
As far as I can see (have tried) dual audio doesn't work with Isengard
(2015-08-28, 08:37)getafix Wrote: [ -> ]As far as I can see (have tried) dual audio doesn't work with Isengard
It sure does! And I think many users will agree.
mmmm, I tried the latest Isengard with the Helix patch and kept getting a python27.dll error.
installed helix and no problem.
(2015-08-28, 08:42)RuudM Wrote: [ -> ]
Yes, the Isenguard patch works (although I don't use it anymore).
(2015-08-28, 08:52)getafix Wrote: [ -> ]mmmm, I tried the latest Isengard with the Helix patch and kept getting a python27.dll error.
How did you mix them? Clean install of Isenguard DA version downloaded from here works no problems, or 15.0 did as haven't tried 15.1 just released.
getafix doesn't use OpenELEC, he is using Windows. Last available Kodi dual audio build from xhbl is Helix 14.2.
As some of you use Kodi for Windows, I compiled a dual audio version of it (Kodi Isengard 15.1). Wink
Just install Isengard 15.1 from official Kodi page, then replace Kodi.exe and the 4 xml setting files.
Please confirm if that dual audio build for Windows does it's job (and please don't complain about any other bugs which are not related to that dual audio patch).
___________________________________________________________________
Edit: Re-Uploaded Patch for correct tag interpretation (stable instead of prealpha)
Edit 2: Here is the patch source archive used for OpenELEC 5.95.4 and Kodi for Windows.
(2015-08-28, 21:20)DarkAngel2401 Wrote: [ -> ]As some of you use Kodi for Windows, I compiled a dual audio version of it (Kodi Isengard 15.1). Wink
Great News. Thx for your work and time. Will try as soon as possible an post feedback.
Just updated to 15.1 with the patch and it seems to work great. Thank you very much.
The only thing is that the version checker tells you that you are using 15.1 pre alpha but that there is the stable version.
Thx
Thank you for that quick check. I reuploaded the file (Dropbox link is the same) with correct tag version interpretation (stable instead of prealpha).
