Thanks DarkAngel...will test this as soon as possible
(2016-03-24, 20:02)epicfail Wrote: [ -> ]Thanks DarkAngel...will test this as soon as possible
Do you rly know what to do with that patch file?
You have to prepare a build environment (Visual C++ 2013 Edition), clone the git Repository, apply the patch and build kodi from sources.
_____________________________
Update: All dual audio OpenELEC versions have been uploaded. Link is in my signature.
No, i dont know what to do with the patch file...but i will test you openelec builds again...
(2016-03-25, 23:38)thor2002ro Wrote: [ -> ]seams no one wants to build dual audio kodi for windows again.... here it is... seams to work fine can't really test it because not near my htpc....
EDIT:tested work excellent
16.1rc2
http://www.mediafire.com/download/a7wz80...Jarvis.rar
GREAT!!!!!
I'll test ASAP
EDIT: Tested on Windows 10... works like a charm
Thanks a lot
I'm a little confused. Do you mean a Jarvis RC2 version is out? If so, I feel like a noob because I can't find it.
