Full Version: w_scan, signal ok but no channels
Hi, I've been trying to get local channels working in XBMCuntu. I have followed the instructions on the XBMX vdr wiki. The Scan Command was giving me issues so I used w_scan. A strange thing is happening however. WHen it scans the channels. It act's like it sees the freq, but when its done says found (0) services. I'm using an ATI HD tunner card. had it working before on a lubuntu install.
Any Ideas?
sample output
@XBMC1:~$ w_scan -fa -A1 -c US > channel.list
w_scan version 20140118 (compiled for DVB API 5.6)
using settings for UNITED STATES
ATSC
VSB US/CA, DVB-T TW
scan type TERRCABLE_ATSC, channellist 1
output format vdr-2.0
WARNING: could not guess your codepage. Falling back to 'UTF-8'
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
        /dev/dvb/adapter0/frontend0 -> TERRCABLE_ATSC "Nextwave NXT200X VSB/QAM frontend": good :-)
Using TERRCABLE_ATSC frontend (adapter /dev/dvb/adapter0/frontend0)
-_-_-_-_ Getting frontend capabilities-_-_-_-_
Using DVB API 5.6
frontend 'Nextwave NXT200X VSB/QAM frontend' supports
INVERSION_AUTO
8VSB
QAM_64
QAM_256
FREQ (54.00MHz ... 860.00MHz)
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
57000: 8VSB(time: 00:00)
63000: 8VSB(time: 00:04)
69000: 8VSB(time: 00:07)
79000: 8VSB(time: 00:10) (time: 00:12) signal ok:
        8VSB     f=79000 kHz
85000: 8VSB(time: 00:12)
177000: 8VSB(time: 00:16)
183000: 8VSB(time: 00:19)
189000: 8VSB(time: 00:22)
195000: 8VSB(time: 00:26)
201000: 8VSB(time: 00:29)
207000: 8VSB(time: 00:33)
213000: 8VSB(time: 00:36) (time: 00:37) signal ok:
        8VSB     f=213000 kHz
473000: 8VSB(time: 00:39)
479000: 8VSB(time: 00:42)
485000: 8VSB(time: 00:45)
491000: 8VSB(time: 00:49) (time: 00:50) signal ok:
        8VSB     f=491000 kHz
497000: 8VSB(time: 00:51)
503000: 8VSB(time: 00:54)
509000: 8VSB(time: 00:57)
515000: 8VSB(time: 01:01) (time: 01:02) signal ok:
        8VSB     f=515000 kHz
521000: 8VSB(time: 01:02)
527000: 8VSB(time: 01:06) (time: 01:07) signal ok:
        8VSB     f=527000 kHz
533000: 8VSB(time: 01:07)
539000: 8VSB(time: 01:11) (time: 01:12) signal ok:
        8VSB     f=539000 kHz
545000: 8VSB(time: 01:12)
551000: 8VSB(time: 01:15)
557000: 8VSB(time: 01:19) (time: 01:20) signal ok:
        8VSB     f=557000 kHz
563000: 8VSB(time: 01:20) (time: 01:21) signal ok:
        8VSB     f=563000 kHz
569000: 8VSB(time: 01:22)
575000: 8VSB(time: 01:25) (time: 01:26) signal ok:
        8VSB     f=575000 kHz
581000: 8VSB(time: 01:27)
587000: 8VSB(time: 01:30) (time: 01:32) signal ok:
        8VSB     f=587000 kHz
593000: 8VSB(time: 01:33)
599000: 8VSB(time: 01:36)
605000: 8VSB(time: 01:39)
611000: 8VSB(time: 01:43)
617000: 8VSB(time: 01:46)
623000: 8VSB(time: 01:50)
629000: 8VSB(time: 01:53)
635000: 8VSB(time: 01:56) (time: 01:58) signal ok:
        8VSB     f=635000 kHz
641000: 8VSB(time: 01:58)
647000: 8VSB(time: 02:02)
653000: 8VSB(time: 02:05)
659000: 8VSB(time: 02:08)
665000: 8VSB(time: 02:12) (time: 02:13) signal ok:
        8VSB     f=665000 kHz
671000: 8VSB(time: 02:13)
677000: 8VSB(time: 02:17) (time: 02:18) signal ok:
        8VSB     f=677000 kHz
683000: 8VSB(time: 02:18)
689000: 8VSB(time: 02:22)
695000: 8VSB(time: 02:25) (time: 02:26) signal ok:
        8VSB     f=695000 kHz
701000: 8VSB(time: 02:26)
707000: 8VSB(time: 02:30)
713000: 8VSB(time: 02:33)
719000: 8VSB(time: 02:37)
725000: 8VSB(time: 02:40)
731000: 8VSB(time: 02:43)
737000: 8VSB(time: 02:47)
743000: 8VSB(time: 02:50)
749000: 8VSB(time: 02:54)
755000: 8VSB(time: 02:57)
761000: 8VSB(time: 03:01)
767000: 8VSB(time: 03:04)
773000: 8VSB(time: 03:07)
779000: 8VSB(time: 03:11)
785000: 8VSB(time: 03:14)
791000: 8VSB(time: 03:18)
797000: 8VSB(time: 03:21)
803000: 8VSB(time: 03:24)
tune to: 8VSB     f=79000 kHz
(time: 03:28) Info: no data from PAT
Info: no data from VCT(terrestrial)
tune to: 8VSB     f=213000 kHz
(time: 03:34) Info: no data from PAT
tune to: 8VSB     f=491000 kHz
(time: 03:42) Info: no data from PAT
tune to: 8VSB     f=515000 kHz
(time: 03:49) Info: no data from PAT
tune to: 8VSB     f=527000 kHz
(time: 03:55) Info: no data from PAT
tune to: 8VSB     f=539000 kHz
(time: 04:02) Info: no data from PAT
tune to: 8VSB     f=557000 kHz
(time: 04:08) Info: no data from PAT
tune to: 8VSB     f=563000 kHz
(time: 04:15) Info: no data from PAT
tune to: 8VSB     f=575000 kHz
(time: 04:21) Info: no data from PAT
tune to: 8VSB     f=587000 kHz
(time: 04:28) Info: no data from PAT
tune to: 8VSB     f=635000 kHz
(time: 04:35) Info: no data from PAT
tune to: 8VSB     f=665000 kHz
(time: 04:41) Info: no data from PAT
tune to: 8VSB     f=677000 kHz
(time: 04:48) Info: no data from PAT
tune to: 8VSB     f=695000 kHz
(time: 04:54) Info: no data from PAT
dumping lists (0 services)
Done.
Got It Working. Turns out I didn't have my drivers and firmware fully installed, like I thought.
For Ubuntu
ATI HD Wonder
wget http://pyther.net/files/firmware/nxt2004...nxt2004.fw # gets Firmware
cp dvb-fe-nxt2004.fw /lib/firmware # copies Firmware to appropriate directory
reload appropriate module or reboot
dmesg #to confirm firmware was loaded
Source: http://pyther.net/2012/07/nxt2004-firmware/
http://ubuntuforums.org/showthread.php?t=2194931
