(2015-08-14, 11:23)Dc0de Wrote: [ -> ]Thank you Spoyser. My missing "globle add to super favourites context menu" fixed. It was the keymap program overriding your override of the keymap to your custom context menu.
I'm also getting the problem as in post #917. I go to another add on (hint - opposite of pepper), do a search, highlight the item I want to add to super favourites, press a button on remote to bring up your custom context menu, and then press the add to superfavourites, select the superfavourites folder. When I then navigate in OSMC on the raspberry pi 1, to the superfavourites add on, it says plugin name instead of the item name next to the item I just added.
Amazing plugin by the way!
Cheers, I will take a look at the other issue over the weekend.
spoyser - any thoughts on this? Thanks!
(2015-08-12, 04:29)springroll Wrote: [ -> ] (2015-08-11, 23:07)spoyser Wrote: [ -> ] (2015-08-11, 17:14)springroll Wrote: [ -> ]This works great! Thanks!
Now I have another question. I added a Super Favorites folder as a widget to the home screen. The widget works fine and the items in the folder would show up correctly too. The problem is that once I'm in the individual add-on of the items within the folder, once I hit the remote to go back, it doesn't go back to the Super Favorites folder menu, instead it goes back to the main Video menu. Is there something I need to do when setting up the widget, so it would return to the folder when leaving the add-on from the folder?
Sorry for making it sound more convoluted than it actually is.
What skin is this with?
Hitcher's FTV skin in the WIP section
Can you try the latest version from my repo (1.0.38.2), I believe it already fixed in that version
(2015-08-14, 15:50)springroll Wrote: [ -> ]spoyser - any thoughts on this? Thanks!
(2015-08-12, 04:29)springroll Wrote: [ -> ] (2015-08-11, 23:07)spoyser Wrote: [ -> ]What skin is this with?
How do I get this skin, can't find it in the main repo.
Sorry - should've provided you the link earlier
http://forum.kodi.tv/showthread.php?tid=207475
(2015-08-14, 19:57)spoyser Wrote: [ -> ] (2015-08-14, 15:50)springroll Wrote: [ -> ]spoyser - any thoughts on this? Thanks!
(2015-08-12, 04:29)springroll Wrote: [ -> ]Hitcher's FTV skin in the WIP section
(2015-08-14, 19:52)spoyser Wrote: [ -> ] (2015-08-14, 11:23)Dc0de Wrote: [ -> ]Thank you Spoyser. My missing "globle add to super favourites context menu" fixed. It was the keymap program overriding your override of the keymap to your custom context menu.
Yep that fixed it. Thank you very much Spoyser!
[quote='springroll' pid='2077545' dateline='1439346565']
/quote]
Where do I find the latest zip file for super favourites?
I still have the problem even with your new load of 1.0.38.2 of super favourites with "import failed"
Please help or give me a work around, thanks
Every time I have asked kodi to send me a log to my email address it has never done so. I have a amazon firetv.
Is there a simpler way to get the log to be extracted and seen?
(2015-08-16, 14:35)tharunam Wrote: [ -> ]Every time I have asked kodi to send me a log to my email address it has never done so. I have a amazon firetv.
Other ways yes, simpler probably not.
I assume you are using the log uploader, what happens when you use it?
(2015-08-16, 12:11)spoyser Wrote: [ -> ] (2015-08-16, 00:52)tharunam Wrote: [ -> ]I still have the problem even with your new load of 1.0.38.2 of super favourites with "import failed"
Will need to see a log
Here is the log via another method.
http://xbmclogs.com/pt3nowki2
(2015-08-16, 17:52)tharunam Wrote: [ -> ] (2015-08-16, 12:11)spoyser Wrote: [ -> ] (2015-08-16, 00:52)tharunam Wrote: [ -> ]I still have the problem even with your new load of 1.0.38.2 of super favourites with "import failed"
What are you doing when you get the error?
