Full Version: Xbmc wont start /start-up crash
Hi there
I have been searching around the forum trying to solve my start-up problems with xbmc, but with no success.
The problem is, that everytime I try to start up the program, i only get as far as the startup screen. No matter how long i let it "think" nothing happens. If i enter the task manager, it also tells me that xbmc is not responding.
I checked the log and som warnings came up, but had no idear what to do with them:
22:12:58 T:7916 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
22:12:58 T:7916 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
Here is the whole log: http://xbmclogs.com/show.php?id=181501
Hope any of you guys are able to help out.
By the way.... I allready did try to reinstall, and try different versions, and my drivers should all be up to date
Okay tried to change loglevel to 1, and it gave me this log now: http://pastebin.com/jzynSc1f
I made some adjustments and the only errors i get now are these:
ERROR: special://masterprofile/guisettings.xml, Line 0
Failed to open file
ERROR: Unable to load special://masterprofile/guisettings.xml, creating new special://masterprofile/guisettings.xml with default values
Does this make any sence
