2014-04-22, 15:36
2014-04-22, 20:10
Builds have been available since this morning.
2014-04-23, 10:25
Working fine for me running from source.
2014-05-25, 01:25
Is tvheadend locking up for anyone running ubuntu 14.04?
Ever since I upgraded my server to 14.04 Tvheadend has being locking up the whole server, there is nothing in the logs and I can not connect while it is locked to look at anything.
At the moment I have stopped tvheadend running which is the first time in years!
I gave tried the latest versions and older ones too but still the same.
Any advice or help?
Any advice or help?
2014-05-25, 16:25
I'm not (yet) on 14.04, so I can't comment, but have you tried enabling debugging in tvheadend to see if that gives you more?
Alternatively, if the machine locks but doesn't crash, you could leave the web interface open with debugging messages showing (the icons at the bottom of the screen) and/or use tail -f on syslog with a large scroll buffer so you could at least see if anything untoward happened. My gut feeling is that it's unlikely to be tvheadend itself as it shouldn't have direct access to anything that could break the system unless you're running it as root - it's more likely to be a hardware/kernel/driver issue that the video subsystem is showing up.
2014-05-30, 23:11
I'm running tvheadend 3.4 (stable) on my ubuntu 14.04 server vm on my esxi host. No lockups, no freezes - it works just fine.
So I agree, it has probaby to do with kernel / drivers / hardware - outside of tvheadend
