Full Version: XBMC-RPI freeze
Hello to all
I have a problem with my XBMC on RPI with Raspbian OS.
After several hours that do not use it freezes and I have to restart the service via ssh.
On the TV I see the mask of XBMC but it does not work anything.
Here you can find the log.
Thank you.
hello, when watching a movie or TV show, did you happen to reset your audio feature?
In audio feature did you increase your decibale rate? it's the first top bar when you go into y our audio feature when you are watching a movie or tv show. If you increase this for some reason it will freeze you pi while watching a movie or live TV. Put it back to Zero.
Hello and thanks for the reply.
No I have not changed anything and in any case the value is 0.
While watching a movie has never blocked, it just hangs after several hours that do not use it.
