2014-04-25, 00:33
I have installed (xbmcbuntu-12.2.Intel-NVIDIA.iso 03-May-2013 13:50 669M) on to my Zotac Zbox ID81-Plus-U Hard Drive. Install went fine. It recognized wireless connection and completed successfuly. On reboot it loads fine until just after the wireless connection light goes on. All of a sudden the XBMC logo disapears, the hard drive light goes off, the is a black screen with the mouse cursor in the middle. What is going on? I cant even get a OpenElec build to work, i get erroes on boot. Ist it the Hardware? Do I need to return this particular Zotac Zbox ID81-Plus-U? Specs are as follows:
Mfr Part# ZBOX-ID81-PLUS-
Motherboard: North Bridge
Chipset: Intel HM65 Express
Processor Brand Supported: Intel
Included Processor: Intel Celeron 857 1.2 GHz Dual-Core
Level 2 Cache: 512KB
Socket Type: BGA1023
CPU Type: Intel Celeron Dual Core
CPU Main Features
Intel Virtualization Technology (VT-x)
Intel 64
Idle States
Enhanced Intel SpeedStep Technology
Thermal Monitoring Technologies
Intel Fast Memory Access
Intel Flex Memory Access
Execute Disable Bit
Intel VT-x with Extended Page Tables (EPT)
Memory RAM Installed: 2048MB DDR3-1333 RAM
Maximum RAM Supported: Upgradeable to 16GB
Memory Slots Available: (2) 204-pin SODIMM Slots
Memory Type: DDR3-1333
Memory Speed: DDR3-1333
Form Factor (0) 204-pin SODIMM Slot
Memory Slots 2
Memory Slots (Available) 0
Memory Technology Supported: SODIMM
Hard Drive: 320GB 2.5" SATA Hard Drive
HD Interface: SATA 6Gb/s
HD RPM: 5,400 RPM
Video Card: Intel HD Graphics
Audio Sound Card: High Definition Audio Chipset
Sound Output Mode: 2-Channel
Networking: 10/100/1000 Gigabit Network; 802.11b/g/n Wireless
LAN: 10/100/1000 Mbps
(1) 6-in-1 Memory card reader, Headphone/Audio out jack, (1) Microphone jack, (1) WiFi antenna connector, (2) USB 3.0 ports, (2) USB 2.0 ports, (1) HDMI Port, (1) DVI Port, (1) 10/100/1000 Ethernet (RJ-45), (1) Digital S/PDIF output, (1) Power connector
What's in the Box
ZOTAC ZBOX ID81, Power brick & cable, VESA monitor mount (w/4 screws), Stand, WiFI antenna, Media Remote w/ USB IR receiver
I do not want to spen to much time on this i just want to Run XBMC with the remote as it should run. Please help. My only other choice is to install Windows 7 and all that overhead. Thank you in advance
CPU Main Features
Intel 64
Idle States
Execute Disable Bit
Memory Slots 2
HD RPM: 5,400 RPM
What's in the Box
