08:55:49 T:140735101530896 DEBUG: ------ Window Init (DialogAddonInfo.xml) ------
08:55:49 T:140735101530896 INFO: Loading skin file: DialogAddonInfo.xml, load type: KEEP_IN_MEMORY
08:55:49 T:140735101530896 DEBUG: Load DialogAddonInfo.xml: 8.97ms
08:55:49 T:140735101530896 DEBUG: Alloc resources: 9.34ms (9.02 ms skin load)
08:55:50 T:140735101530896 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
08:55:50 T:140735101530896 DEBUG: OnKey: return (0xf00d) pressed, action is Select
08:55:50 T:4596305920 DEBUG: FileManager: copy http://hitcher-repo.googlecode.com/svn/trunk/skin.conq/skin.conq-0.9.8.zip -> special://home/addons/packages/skin.conq-0.9.8.zip
08:55:50 T:4596305920 DEBUG: CurlFile::Open(0x1107b9790) http://hitcher-repo.googlecode.com/svn/trunk/skin.conq/skin.conq-0.9.8.zip
08:55:50 T:140735101530896 DEBUG: ------ Window Deinit (DialogAddonInfo.xml) ------
08:55:51 T:4596305920 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
08:55:51 T:4596305920 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
08:55:51 T:4596305920 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
08:55:51 T:4596305920 ERROR: DeleteFile - cant delete file </Users/***/Library/Application Support/XBMC/addons/packages/skin.conq-0.9.8.zip>. trying lower case </users/***/library/application support/xbmc/addons/packages/skin.conq-0.9.8.zip>
08:55:51 T:140735101530896 DEBUG: CGUIMediaWindow::GetDirectory (addons://xbmc.repo.hitcher/xbmc.gui.skin)
08:55:51 T:140735101530896 DEBUG: ParentPath = [addons://xbmc.repo.hitcher/xbmc.gui.skin]
08:55:51 T:4614234112 NOTICE: Thread BackgroundLoader start, auto delete: false
08:55:51 T:4614234112 DEBUG: Thread BackgroundLoader 4614234112 terminating
I'm having the same issue. I go to download, it flashes 0% and that's it. Here's a clip of the debug log.
I am having the same issue as dfa82.
dfa82, Scott00007
There is no v0.9.8 hosted. The latest version is still v0.9.7. Looks as if
Hitcher had forgotten to upload it or has problems in this regard.
Just be patient.
Hitcher will be take care of it
Yeah, looks like updating iPlayer I accidentally bumped Conq.
Cool! No problem. Excited to give this a shot on the big screen, and not just the computer.
Hi Hitcher,
Thnx for this skin..
I have a problem to see the difference between selected and non selected text.
I have to switch between them to actually see the difference. Is this something on my side, and is there a way I can change the color/intensity of the selected text?
(2014-05-19, 09:06)Marco275 Wrote: [ -> ]Hi Hitcher,
You can change the colours in skin.conq\colors\Default.xml - but be aware, that you'll have to do it after every update. To avoid this, edit the colors in the file default.xml, save as NameOfMyColours.xml and chose your colors in the settings (Appearence/Skin/-Colours).
Chosing (or making) a slightly darker background picture also helps. The background jpg-files are in skin.conq\extras\backgrounds
Any possibility of adding an option to switch the watched/unwatched icons? I'd like to have unwatched be marked and watched be unmarked. Trying to dabble in the editing it myself but have no idea what I'm doing.
I still don't understand why a few people are having this problem. Could it be a limited RGB thing?
I would like to see changes, but 3 days impossible to download conq with REPO
Hi Hitcher,
(2014-05-19, 16:05)Hitcher Wrote: [ -> ]I still don't understand why a few people are having this problem. Could it be a limited RGB thing?
Same problem for me with a fresh install of XBMCbuntu with XBMC 13.0.
My graphic card is an AMD Fusion...
What de you exactly mean when you said "Could be a limited RGB thing?" ?
Have you checked your colour temperature isn't too high resulting in blueish whites?
hitcher, is there a known problem with the REPO, I can not install conq! thank you
It s good ; thx
