(2014-05-21, 08:25)aschwerin.moses Wrote: [ -> ]Great skin.
Replacing this as my default skin.
Requests:
- Is it possible to provide a horizontal menu view on the home window. Humble request.
- Option to set multiple images for every menu (like aeon nox).
+1 for the horizontal menu view option
I wish..
however i use the below remote and to search/type i use the remote function on the remote. The keyboard thing on the remote is head ache.
Its your skin and u have the right to not change. Request you to guide me to replace the cursor.
I have just updated to .9.9.1 and for some reason I have lost the home sub-menu options for TV and Movies. Before I updated my newly added episodes would show on the home screen and now there is no option in the home sub-menu option does not have those options available. The first option I have is for a album sub-menu. I have uploaded a log #206663.
Another thing, I love the curve option that has been added. I am just wondering if there is supposed to be any "curves" on the home screen as I am not seeing them there but I am seeing them most other places.
(2014-05-21, 14:16)Scott00007 Wrote: [ -> ]I have just updated to .9.9.1 and for some reason I have lost the home sub-menu options for TV and Movies. Before I updated my newly added episodes would show on the home screen and now there is no option in the home sub-menu option does not have those options available. The first option I have is for a album sub-menu. I have uploaded a log #206663.
Just use the reset button in the skin settings.
BTW i completely missed the update and the included LiveTV. Running Conq on all machines now, so again: Awesome work Hitcher.
Awesome! Thanks, that fixed it.
i reset the skin settings to get the unwatched movies/tv-shows widget back. after that the watched/unwatched icon's are lost o0
anyone, know this problem?
@ ascherwin
do you have a full functional lircmap.xml for this remote control
If, could you please post it?
Kind regards
Oliver
Freaking great work! I just updated all my Frodo boxes to Gotham just to use this skin. Love the minimalism.
Hitcher - is it on your road map for this skin to have custom menu options? For example if a user wanted to add a direct link to the 'Recordings' section of Live TV on the home page?
(2014-05-21, 13:32)aschwerin.moses Wrote: [ -> ]I wish..
Edit the Pointer.xml.
(2014-05-21, 16:41)lefy Wrote: [ -> ]i reset the skin settings to get the unwatched movies/tv-shows widget back. after that the watched/unwatched icon's are lost o0
Fixed in v9.9.91.
(2014-05-21, 17:52)jkirk Wrote: [ -> ]Freaking great work! I just updated all my Frodo boxes to Gotham just to use this skin. Love the minimalism.
I did think of having separate entries on the home menu for Live TV but as I don't use it myself I wasn't sure it would be useful.
(2014-05-21, 18:07)Hitcher Wrote: [ -> ]I did think of having separate entries on the home menu for Live TV but as I don't use it myself I wasn't sure it would be useful.
Jeah there is one problem with LiveTV ATM: If you enter the EPG Timetable view, you can never go back to the channel list. No way to get the menu to open because you can navigate in all directions.
Just keep going left.
Isn't this same in all skins as I've based this on Confluence and Xperience108 code?
(2014-05-21, 17:12)liquidolze Wrote: [ -> ]@ ascherwin
Kind regards
Oliver
Not required. This is a simple plug and play. Works perfectly. The only discomfort is the typing part.
@Hitcher: what I did is use <onback> on the container to skip to the menu directly. Something to consider maybe?
(2014-05-21, 18:12)Lucleonhart Wrote: [ -> ] (2014-05-21, 18:07)Hitcher Wrote: [ -> ]I did think of having separate entries on the home menu for Live TV but as I don't use it myself I wasn't sure it would be useful.
(2014-05-21, 19:01)Hitcher Wrote: [ -> ]Just keep going left.
If you don't use past epg data you can disable the feature by adding this to your advancedsettings.xml:
<epg>
<lingertime>0</lingertime>
</epg>
Tommy
PS or you can use the entry to limit the amount of past data is kept... thus reducing the number of left clicks to reach the TV menu.
Hitcher
I know the Live TV stuff is a huge drag for you but thanks for doing it. It looks great.
As for the custom menu item thing - I think the way the PVR functions are designed in the core program it is a pain to get to the main features of PVR - which is the EPG and the Recordings tabs. Being able to add them as direct links (via favourites or whatever) would be tremendously useful. At least for the PVR folks.
Thanks again!
