Really?
I just assumed it would be next year as they tend to be about a year apart.
no, i heard i would be most probably much earlier. but of course i'm not sure.
but it is fully understandable that you do not want to do the extra work. i'm always hanging at the git version (more or less) so i guess i have to be patient
am i missing something but it seems the current changes related to pvr is not for helix but its for Gotham 13.2.
it seems in git thi has been tagged now as 13.2b2 Gotham.
Love the skin! Been waiting for a great looking minimal skin & this one fits the bill! Thanks. I have something's I might try to tweek like another row of movies in wall view. That's for later though.
I know you've frozen development on this skin, but for now could you at least add cinema exprience plugin. Only thing this is missing.
Thanks for putting in the time with this. Cheers!
Mark
Anything new!?
Efty
best skin I've seen for XBMC, keep up the good work!
Do I spot a RC??
My system is coming up with a dependency problem. Will post more when I get home this evening.
Great work as always Hitcher!
I am unable to update to the RC, dependency problems on Android and Linux......can't wait to see the changes!!!!
It's just waiting for the latest skin shortcuts script to be pushed to the official repo, alternatively you can manually get it from
here.
And yes this means completely customisable main menu, sub menus, and widgets on the home screen.
Dependency problem for the skin shortcuts script as well......anyone get it to work on Linux??
Script.module.unidecode, also on my github.
Thanks...worked perfectly.
Favorites are not showing on the home screen. The menu is there of course but the favorite widget isn't showing up. Same way on both Android and Linux.
Awesome. Works great.
Found a small bug, will post in the bug thread
(2014-08-14, 19:57)malabarth Wrote: [ -> ]I just have a little problem, I can't curtomize music sub-menu. I only have "Files" inside beside the fact I've enabled other shortcut in the skin settingq!
Any advice/help?
Thanks again!
Do you have any music in your library? Most of the standard music submenu items - artists, albums and so on - rely on having scanned your music into the library, and so aren't visible if the library is empty. (Files view doesn't use the library and so is always visible)
