(2014-08-21, 19:19)Hitcher Wrote: [ -> ] (2014-08-21, 17:27)Xmassacrex Wrote: [ -> ]Love the skin. Only problem I have found is that when a link requires a captcha,the keyboard appears over it, making it very difficult to decipher the captcha! As soon as this is fixed it will be my default theme. Great theme none the less though
Can you turn on the 'debug labels' and let me know which dialogs are present when this happens.
Hi Hitcher. Turned on debug logging and here are the results from when i click the link in which a captcha appears!
12:17:33 T:2429543488 NOTICE: Icefilms: Entering Stream Source with options - Name: Source #3 | 180 | [COLOR red]HD[/COLOR] | Full Url:
http://180upload.com/fdwaz1tg5vtc DownloadPlay: False Download: False Stacked: False
12:17:34 T:2885379136 DEBUG: Skin Widgets: Total time needed to request random queries: 0:00:08.768171
12:17:34 T:2429543488 DEBUG: DialogProgress::StartModal called
12:17:34 T:2429543488 DEBUG: ------ Window Init (DialogProgress.xml) ------
12:17:34 T:2429543488 INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
12:17:34 T:2429543488 DEBUG: Icefilms: 180Upload - Requesting GET URL:
12:17:35 T:3037176608 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
12:17:40 T:2429543488 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-arm.so)
12:17:40 T:2429543488 DEBUG: Loading: /opt/xbmc-bcm/xbmc-bin/lib/xbmc/system/ImageLib-arm.so
12:17:40 T:3037176608 DEBUG: ------ Window Init () ------
12:17:43 T:3037176608 INFO: Loading skin file: DialogKeyboard.xml, load type: KEEP_IN_MEMORY
12:17:43 T:3037176608 DEBUG: ------ Window Init (DialogKeyboard.xml) ------
12:17:43 T:3037176608 DEBUG: CAnnouncementManager - Announcement: OnInputRequested from xbmc
12:17:43 T:3037176608 DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputRequested
12:18:03 T:2446320704 DEBUG: Thread JobWorker 2446320704 terminating (autodelete)
12:18:10 T:3037176608 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-arm.so)
12:18:10 T:3037176608 DEBUG: Unloading: ImageLib-arm.so
12:18:23 T:3028780096 DEBUG: CAESinkPi
rain delay:99ms now:0ms
12:18:32 T:2933912640 DEBUG: CecLogMessage - >> 01:44:00
12:18:32 T:2933912640 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
12:18:32 T:2933912640 DEBUG: CecLogMessage - key pressed: select (0)
12:18:32 T:2933912640 DEBUG: PushCecKeypress - received key b duration 0
12:18:32 T:3037176608 DEBUG: OnKey: 11 (0x0b) pressed, action is Select
12:18:32 T:3028780096 NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:2205)
12:18:32 T:2933912640 DEBUG: CecLogMessage - >> 01:8b:00
12:18:32 T:2933912640 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): vendor remote button up (8B)
12:18:32 T:2933912640 DEBUG: CecLogMessage - key released: select (0)
12:18:32 T:2933912640 DEBUG: PushCecKeypress - received key b duration 70
12:18:32 T:3037176608 DEBUG: ------ Window Deinit (DialogKeyboard.xml) ------
12:18:32 T:3037176608 DEBUG: CAnnouncementManager - Announcement: OnInputFinished from xbmc
12:18:32 T:3037176608 DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputFinished
12:18:32 T:2429543488 ERROR: Icefilms: **** 180Upload Error occured: You must enter text in the image to access video
If I've missed anything out I apologise. Thanks for the reply. Look forward to using your skin again
