Maybe my new favorite skin. But I guess this is 1080 only? I don't know, it looks a bit compressed for me, with a 720p screen.
A suggestion, put movie rating somewhere in the listing?
(2014-05-10, 14:10)rapid_pete Wrote: [ -> ]great work hitcher!
only one thing: i can't play an album by clicking on the homescreen thumbnail.
movies and tv shows working perfectly.
What type are you using?
(2014-05-10, 15:58)monsieurpaulu Wrote: [ -> ]nice work !! i really like it.
i have seen that the original idea on conq plex was to have some curved segments in the background.
are you also going to add those in the future ? (maybe as an option )
i think it makes the skin even more beautiful
As the original designer decided to remove them I don't have access to the textures.
(2014-05-10, 17:22)Hitcher Wrote: [ -> ]
Conq for 9.5 Plex
Honestly I am totally against the curved background so if it will come I hope it's just an option...
Also the volume control might benefit from a visual indicator, rather than a number; and I don't know if this is intended, but it increases/decreases in steps of 1% per keypress.
Turns out I did have the curve texture but I won't be adding it anyway.
(2014-05-11, 01:21)Hitcher Wrote: [ -> ]Turns out I did have the curve texture but I won't be adding it anyway.
Not even as an option? It would be great if you did.
(2014-05-11, 02:32)Scott00007 Wrote: [ -> ] (2014-05-11, 01:21)Hitcher Wrote: [ -> ]Turns out I did have the curve texture but I won't be adding it anyway.
It'd be great to see the curves as an option, as well as more background colour choices.
+1 for a curved background option. In my opinion it makes it a little less flat. Other than that it's a great skin which runs perfectly on my low end spare Htpc
(2014-05-10, 17:22)Hitcher Wrote: [ -> ] (2014-05-10, 14:10)rapid_pete Wrote: [ -> ]great work hitcher!
i'm using openelec gotham final, conq version is 0.9.7 from your repo.
maybe this debug log snippet helps to clear things up.
DEBUG: OnKey: return (0xf00d) pressed, action is Select
09:45:12 T:139644862236480 ERROR: Keymapping error: no such action 'playmedia()' defined
09:45:12 T:139644862236480 DEBUG: ExecuteXBMCAction : Tried translating,
but failed to understand PlayMedia($ESCINFO[Window(home).Property(RandomAlbum.3.Path)])
09:45:34 T:139644862236480
(2014-05-10, 05:30)username145 Wrote: [ -> ]Loving it so far, but a couple of suggestions -- wondering if you could have the current time display somewhere in the info OSD? Also, IMO the scrolling animation for the "Wide" poster view doesn't jive with the rest of the skin (again, just IMO), something simpler, or just removing the "spring" effect would suit better
This is actually also my only gripe with this theme.
(2014-05-11, 11:52)BartLibert Wrote: [ -> ] (2014-05-10, 05:30)username145 Wrote: [ -> ]Loving it so far, but a couple of suggestions -- wondering if you could have the current time display somewhere in the info OSD? Also, IMO the scrolling animation for the "Wide" poster view doesn't jive with the rest of the skin (again, just IMO), something simpler, or just removing the "spring" effect would suit better
I've sort-of solved the latter, open "Viewtype52.xml" and change both instances of "zoom" to "slide". Seems to work, but I don't really know what I'm doing so it could probably be done better.
Fantastic Skin.
I am running Xperience1080+ since a year now, but i think its time to switch when LiveTV is implemented.
Loving it, keep up the good work! *rep+*
