2014-04-27, 17:51
Pages: 1 2
2014-04-27, 23:46
They should work everywhere - all it does is compute the correct <left>, <right> etc. absolute coordinates on control allocation.
2014-04-28, 00:00
So the following code should result in the texture being centrally aligned and half the size of it's parent?
Because I end up with the texture in the centre but it's only 50x50px.
PHP Code:
<control type="group">
<left>0</left>
<top>0</top>
<width>1920</width>
<height>1080</height>
<!-- Dialog background image -->
<control type="image">
<centerleft>50%</centerleft>
<centertop>50%</centertop>
<width>50%</width>
<height>50%</height>
<texture border="10">dialogs/DialogBackgroundImage.png</texture>
</control>
</control>
2014-04-28, 00:20
Looks like a bug - it will work if you do <width min="50%" max="50%">auto</width> right?
(Probably your labels were already using this?)
2014-04-28, 08:12
That worked for the size but now it's not centered.
2014-04-28, 10:22
Make sure that <left> and <top> aren't defined in defaults.xml. That's usually the cause.
In the meantime, I'll do up a fix for <width>50%</width>
2014-04-28, 10:39
Fixed in master - that'll get backported to Gotham.
2014-04-28, 18:21
(2014-04-28, 10:22)jmarshall Wrote: [ -> ]Make sure that <left> and <top> aren't defined in defaults.xml. That's usually the cause.Not in any of my defaults.
(2014-04-28, 10:39)jmarshall Wrote: [ -> ]Fixed in master - that'll get backported to Gotham.For the <width>50%</width> problem?
What I'm trying to achieve here is a base skin where only a minimum of changes are needed (default textures, max width and height of a control group) removing the need to recode entire windows/dialogs but at the same time making a skin look totally different. So basically only two dimensions could be defined and everything else would be based on percentages of the main control group.
Should this be possible now?
2014-04-29, 10:43
Indeed it should be, as long as you want everything to scale the same way.
And yeah, the fix is in for the width/height issue. I could reproduce it fine using Confluence, but my trick above worked OK once I removed the default <left> and <top> from the image control. Reason is that with <left> and <centerleft> both defined, you've nailed down the width as well. Thus, specifying 3 of them gives conflicting information, and one has to give.
2014-04-29, 21:12
2014-04-29, 23:05
Neat
Hadn't considered others, but there's no reason we couldn't. The problem I guess is what they reference? Would they always reference the parent size? If so, what is the parent size of the layout - the size of the container or the size of the group the container is in? Once we sort that it'd be pretty easy to hook it up (you'd also get the 50r stuff for free, though I suspect it doesn't make much sense in most cases!)
(And yeah, nightlies are coming from Gotham branch, so won't include it until I backport - will do so this evening).
2014-04-29, 23:45
I guess it would be consistent to always use the parent whether it's a container or a group.
2014-06-21, 17:12
Do you know by any chance if there's news on the use of percentages inside layouts?
2014-10-04, 15:58
(2014-04-29, 23:05)jmarshall Wrote: [ -> ]Neat
@jmarshall
Any update/progress on this please?
2014-10-04, 18:23
JMarshall > Retired Team-XBMC Developer :-(
Pages: 1 2
