2014-04-30, 09:01
I have had a problem with my MX box,the problem started with the update of Confluence which is the default? i always run the wizard when resetting or playing with my mx box so i got the new island back ground on xbmc only few weeks ago now when it came to update it did what it to did in the picture from the skin with the island backround was on, to solve it i have run wizard again blind as you cannot see what you need to, once a run wizard a got the blue ground then i see its Confluence 7 then i have to go in get other skins look for Confluence 7 then is says update which do then it goes blank for a few minutes and then everything seems ok but wondered just why?. see my pic here after the skin update this is what it looked like any one else with MX box have the same trouble?
http://i1357.photobucket.com/albums/q750...be7094.jpg
http://xbmclogs.com/show.php?id=186989
http://xbmclogs.com/show.php?id=186990
Thanks for the help in this. This what i have
Android 4.2.2
Cpu:
Amlogix mx
Chip:
Dual core A9 1.5Ghz
Ram:
1GB
Rom:
8GB
XBMC:
Pre-installed 12.2
HDMI,AV:
Wifi:
Lan:
Android 4.2.2
Cpu:
Amlogix mx
Chip:
Dual core A9 1.5Ghz
Ram:
1GB
Rom:
8GB
XBMC:
Pre-installed 12.2
HDMI,AV:
Wifi:
Lan:
