2014-05-01, 21:05
2014-05-11, 08:34
You can use the .strm file to display a udp multicast stream
2014-05-11, 16:53
Can you tell me how to open the .strm file? Does xbmc for android look fot this file extension?
2014-05-13, 22:50
I created a stream file with the following contents.
udp://227.6.0.15:1234/
I can open this file using xbmc for windows and xbmc for windows will play the udp stream.
However, when I open the file in xbmc for Android, I get an error dialog box. The dialog box says something like this:
"Playback failed.
One or more items failed to play.
Check the log file for details."
Here is the log file on paste bin.
http://pastebin.com/Ga3duMkN
Can anyone tell me what is going on from the log file?
(I am using version XBMC 14.0-ALPHA1 Git:20140512-af2d1b5)
For the record, page that explains .strm files.
http://wiki.xbmc.org/index.php?title=Int...io_streams
"Playback failed.
2014-05-21, 22:31
FYI,
The problems I was having were on a GPad.
UDP Multicast streams played back as expected on a Nexus 7 tablet.
