Here's a debug log. ADDON_Create() always returns ADDON_STATUS_NEED_SETTINGS. Addon name is FullIPTV.
19:16:31 T:1296 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:16:31 T:1296 NOTICE: -----------------------------------------------------------------------
19:16:31 T:1296 NOTICE: Starting XBMC (13.0-BETA4 Git:20140418-482ccd3). Platform: x86 Win32 32-bit
19:16:31 T:1296 NOTICE: Using Release XBMC x32 build, compiled Apr 19 2014 by MSVC 160040219 for x86 Win32 32-bit version 0x06000000
19:16:31 T:1296 NOTICE: Running on Windows 7 SP1 64-bit, build 7601
19:16:31 T:1296 NOTICE: Host CPU: AMD Athlon(tm) II X4 635 Processor, 4 cores available
19:16:31 T:1296 NOTICE: Desktop Resolution: 1920x1200 32Bit at 60Hz
19:16:31 T:1296 NOTICE: Running with restricted rights
19:16:31 T:1296 NOTICE: Aero is enabled
19:16:31 T:1296 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
19:16:31 T:1296 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
19:16:31 T:1296 NOTICE: special://masterprofile/ is mapped to: C:\Users\Alex\AppData\Roaming\XBMC\userdata
19:16:31 T:1296 NOTICE: special://home/ is mapped to: C:\Users\Alex\AppData\Roaming\XBMC\
19:16:31 T:1296 NOTICE: special://temp/ is mapped to: C:\Users\Alex\AppData\Roaming\XBMC\cache
19:16:31 T:1296 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
19:16:31 T:1296 NOTICE: Local hostname: Alex-PC
19:16:31 T:1296 NOTICE: Log File is located: C:\Users\Alex\AppData\Roaming\XBMC\xbmc.log
19:16:31 T:1296 NOTICE: load settings...
19:16:31 T:1296 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:16:31 T:1296 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:16:31 T:1296 NOTICE: Default DVD Player: dvdplayer
19:16:31 T:1296 NOTICE: Default Video Player: dvdplayer
19:16:31 T:1296 NOTICE: Default Audio Player: paplayer
19:16:31 T:1296 NOTICE: Enabled debug logging due to GUI setting (2)
19:16:31 T:1296 NOTICE: Log level changed to 2
19:16:31 T:1296 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:16:31 T:1296 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:16:31 T:1296 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
19:16:31 T:1296 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
19:16:31 T:1296 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/mms/udp
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
19:16:31 T:1296 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
19:16:31 T:1296 NOTICE: Loaded playercorefactory configuration
19:16:31 T:1296 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:16:31 T:1296 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:16:31 T:1296 INFO: creating subdirectories
19:16:31 T:1296 INFO: userdata folder: special://masterprofile/
19:16:31 T:1296 INFO: recording folder:
19:16:31 T:1296 INFO: screenshots folder:
19:16:31 T:1296 INFO: load language info file: special://xbmc/language/English (US)/langinfo.xml
19:16:31 T:1296 DEBUG: trying to set locale to eng_deu
19:16:31 T:1296 INFO: global locale set to English_Germany.1252
19:16:31 T:1296 INFO: load English (US) language file, from path: special://xbmc/language/
19:16:31 T:1296 DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files (x86)\XBMC\language\English (US)\strings.po
19:16:32 T:1296 DEBUG: POParser: loaded 3162 strings from file C:\Program Files (x86)\XBMC\language\English (US)\strings.po
19:16:32 T:1296 DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files (x86)\XBMC\language\English\strings.po
19:16:32 T:1296 DEBUG: POParser: loaded 0 strings from file C:\Program Files (x86)\XBMC\language\English\strings.po
19:16:32 T:1296 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avutil-52.dll)
19:16:32 T:1296 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avcodec-54.dll)
19:16:32 T:1296 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avformat-54.dll)
19:16:32 T:1296 INFO: msg: p11-kit: couldn't open config file: /home/nmav/cvs/gnutls/win32/win32/etc/pkcs11/pkcs11.conf: No error
19:16:32 T:2368 NOTICE: Thread ActiveAE start, auto delete: false
19:16:32 T:2568 NOTICE: Thread AESink start, auto delete: false
19:16:32 T:2368 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "Realtek HDMI Output (Realtek High Definition Audio)" seems to be not supported.
19:16:32 T:2368 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "Realtek HDMI Output (Realtek High Definition Audio)" seems to be not supported.
19:16:32 T:2368 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "Realtek HDMI Output (Realtek High Definition Audio)" seems to be not supported.
19:16:32 T:2368 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "Realtek HDMI Output (Realtek High Definition Audio)" seems to be not supported.
19:16:32 T:2368 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "Realtek HDMI Output (Realtek High Definition Audio)" seems to be not supported.
19:16:32 T:2368 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AAC" on device "Realtek HDMI Output (Realtek High Definition Audio)" seems to be not supported.
19:16:32 T:2368 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "Realtek HDMI Output (Realtek High Definition Audio)" seems to be not supported.
19:16:32 T:2368 NOTICE: Found 2 Lists of Devices
19:16:32 T:2368 NOTICE: Enumerated DIRECTSOUND devices:
19:16:32 T:2368 NOTICE: Device 1
19:16:32 T:2368 NOTICE: m_deviceName : {29E0F3B2-D63C-4C56-ADC9-89B345C5D944}
19:16:32 T:2368 NOTICE: m_displayName : HDMI - Realtek HDMI Output (Realtek High Definition Audio)
19:16:32 T:2368 NOTICE: m_displayNameExtra: DIRECTSOUND: Realtek HDMI Output (Realtek High Definition Audio)
19:16:32 T:2368 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
19:16:32 T:2368 NOTICE: m_channels : FL,FR
19:16:32 T:2368 NOTICE: m_sampleRates : 48000
19:16:32 T:2368 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
19:16:32 T:2368 NOTICE: Device 2
19:16:32 T:2368 NOTICE: m_deviceName : {2BF29832-8B04-4377-AA71-A0F2AC2DA9EE}
19:16:32 T:2368 NOTICE: m_displayName : SPDIF - Realtek Digital Output(RCA) (Realtek High Definition Audio)
19:16:32 T:2368 NOTICE: m_displayNameExtra: DIRECTSOUND: Realtek Digital Output(RCA) (Realtek High Definition Audio)
19:16:32 T:2368 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
19:16:32 T:2368 NOTICE: Device 3
19:16:32 T:2368 NOTICE: m_deviceName : {E2F6B861-CFC5-4F5F-B13C-FA09EC525089}
19:16:32 T:2368 NOTICE: m_displayName : Speakers - Speakers (Realtek High Definition Audio)
19:16:32 T:2368 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers (Realtek High Definition Audio)
19:16:32 T:2368 NOTICE: m_deviceType : AE_DEVTYPE_PCM
19:16:32 T:2368 NOTICE: Device 4
19:16:32 T:2368 NOTICE: m_deviceName : default
19:16:32 T:2368 NOTICE: m_displayName : default
19:16:32 T:2368 NOTICE: Enumerated WASAPI devices:
19:16:32 T:2368 NOTICE: m_displayNameExtra: WASAPI: Realtek HDMI Output (Realtek High Definition Audio)
19:16:32 T:2368 NOTICE: m_sampleRates : 192000,96000,48000,44100
19:16:32 T:2368 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
19:16:32 T:2368 NOTICE: m_displayNameExtra: WASAPI: Realtek Digital Output(RCA) (Realtek High Definition Audio)
19:16:32 T:2368 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
19:16:32 T:2368 NOTICE: m_displayNameExtra: WASAPI: Speakers (Realtek High Definition Audio)
19:16:32 T:2368 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
19:16:32 T:2368 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
19:16:32 T:2568 INFO: CActiveAESink::OpenSink - initialize sink
19:16:32 T:2568 DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:{E2F6B861-CFC5-4F5F-B13C-FA09EC525089}
19:16:32 T:2568 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 65552
19:16:32 T:2568 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
19:16:32 T:2568 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
19:16:32 T:2568 DEBUG: Audio Device : Speakers (Realtek High Definition Audio)
19:16:32 T:2568 DEBUG: Sample Rate : 44100
19:16:32 T:2568 DEBUG: Sample Format : AE_FMT_FLOAT
19:16:32 T:2568 DEBUG: Bits Per Sample : 32
19:16:32 T:2568 DEBUG: Valid Bits/Samp : 32
19:16:32 T:2568 DEBUG: Channel Count : 2
19:16:32 T:2568 DEBUG: Block Align : 8
19:16:32 T:2568 DEBUG: Avg. Bytes Sec : 352800
19:16:32 T:2568 DEBUG: Samples/Block : 32
19:16:32 T:2568 DEBUG: Format cBSize : 22
19:16:32 T:2568 DEBUG: Channel Layout : FL,FR
19:16:32 T:2568 DEBUG: Channel Mask : 3
19:16:32 T:2568 DEBUG: Frames : 661
19:16:32 T:2568 DEBUG: Frame Samples : 1322
19:16:32 T:2568 DEBUG: Frame Size : 8
19:16:32 T:2568 DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
19:16:32 T:2568 DEBUG: Output Device : Speakers - Speakers (Realtek High Definition Audio)
19:16:32 T:2568 DEBUG: Channel Layout: FL,FR
19:16:32 T:2568 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
19:16:32 T:1296 NOTICE: Running database version Addons16
19:16:32 T:1296 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/cpluff.dll)
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in visualization.vortex has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in weather.wunderground has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.simplejson has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in skin.xperience1080 has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in service.xbmc.versioncheck has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc-wingl windx-x86 has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in skin.confluence has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in visualization.milkdrop has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.common.plugin.cache has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.amazon.de has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in visualization.dxspectrum has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.simple.downloader has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in plugin.video.youtube has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.demo has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.artistslideshow has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.fulliptv has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in skin.touched has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-win32.xbmc.org has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv.cmyth has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.last.fm has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.debug has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.parsedom has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.requests2 has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.hdtrailers.net has been installed.'
19:16:32 T:1296 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
19:16:32 T:1296 NOTICE: ADDONS: Using repository repository.xbmc.org
19:16:32 T:1296 NOTICE: ADDONS: Using repository repository.pvr-win32.xbmc.org
19:16:32 T:6732 NOTICE: Thread RemoteControl start, auto delete: false
19:16:32 T:6732 DEBUG: CRemoteControl::Connect - connecting to: ::1:24000 ...
19:16:32 T:1296 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "Motorola Nyxboard Hybrid"
19:16:32 T:1296 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "CEC Adapter"
19:16:32 T:1296 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "Pulse-Eight CEC Adapter"
19:16:32 T:1296 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "iMON HID device"
19:16:33 T:1296 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcec.dll)
19:16:33 T:3424 NOTICE: Thread PeripBusCEC start, auto delete: false
19:16:33 T:1392 NOTICE: Thread PeripBusUSB start, auto delete: false
19:16:33 T:1296 DEBUG: CWIN32Util::GetDriveStatus: Requesting status for drive \\.\F:.
19:16:33 T:1296 DEBUG: CWIN32Util::GetDriveStatus: Requesting media status for drive \\.\F:.
19:16:33 T:1296 DEBUG: CWIN32Util::GetDriveStatus: Requesting status for drive \\.\L:.
19:16:33 T:1296 DEBUG: CWIN32Util::GetDriveStatus: Requesting media status for drive \\.\L:.
19:16:33 T:1296 NOTICE: Found screen: Acer X243W on AMD Radeon HD 5570, adapter 0.
19:16:33 T:1296 NOTICE: Primary mode: 1920x1200@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Previous line repeats 2 times.
19:16:33 T:1296 NOTICE: Additional mode: 720x480@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 720x576@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x720@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x768@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x800@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x960@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1360x1024@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1366x768@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1400x1050@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1440x900@ 75.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Additional mode: 1920x1200@ 60.00 - Full Screen
19:16:33 T:1296 NOTICE: Checking resolution 16
19:16:33 T:1296 DEBUG: CWinEventsWin32::WndProc: window resize event
19:16:33 T:1296 DEBUG: CWinEventsWin32::WndProc: window move event
19:16:33 T:1296 DEBUG: CWinSystemWin32::ResizeInternal - resizing due to size change (0,0,1920,1200 fullscreen)->(0,0,1920,1200 fullscreen)
19:16:33 T:1296 DEBUG: CWinEventsWin32::WndProcWindow is active
19:16:33 T:6732 DEBUG: CRemoteControl::Connect - connecting to: 127.0.0.1:24000 ...
19:16:34 T:1296 DEBUG: CRenderSystemDX::InitRenderSystem - trying D3D9Ex...
19:16:34 T:1296 DEBUG: CRenderSystemDX::InitRenderSystem - using D3D9Ex
19:16:34 T:1296 DEBUG: CRenderSystemDX::CreateDevice on adapter 0
19:16:34 T:1296 DEBUG: CRenderSystemDX::CreateDevice - using hardware vertex processing
19:16:34 T:1296 DEBUG: CRenderSystemDX::CreateDevice - adapter 0: aticfx32.dll, AMD Radeon HD 5570, VendorId 4098, DeviceId 26841
19:16:34 T:1296 DEBUG: CRenderSystemDX::CreateDevice - using D3DCAPS2_DYNAMICTEXTURES
19:16:34 T:1296 DEBUG: CRenderSystemDX::CreateDevice - texture caps: 0x0001EC45
19:16:34 T:1296 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_DXT
19:16:34 T:1296 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_NPOT
19:16:34 T:1296 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_DXT_NPOT
19:16:34 T:1296 DEBUG: CWinSystemWin32::SetFullScreen (windowed fullscreen) on screen 0 with size 1920x1200, refresh 60.000000
19:16:34 T:1296 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
19:16:34 T:1296 INFO: load default splash image: C:\Program Files (x86)\XBMC\media\Splash.png
19:16:34 T:1296 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib.dll)
19:16:34 T:1296 INFO: load keymapping
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/appcommand.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.Alienware.Dual.Compatible.Controller.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.Interact.AxisPad.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.360.Controller.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.Nintendo.Wii.U.Pro.Controller.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.PS3.Remote.Keyboard.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION(R)3.Controller.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/joystick.xml
19:16:34 T:1296 NOTICE: No Joystick name specified, loading default map
19:16:34 T:1296 NOTICE: Previous line repeats 35 times.
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/mouse.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/remote.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
19:16:34 T:1296 INFO: Loading special://xbmc/system/IRSSmap.xml
19:16:34 T:1296 INFO: * Adding remote mapping for device 'Microsoft MCE'
19:16:34 T:1296 INFO: * Adding remote mapping for device 'Abstract'
19:16:34 T:1296 DEBUG: CButtonTranslator::Load - no userdata IRSSmap.xml found, skipping
19:16:34 T:1296 INFO: GUI format 1920x1200, Display 1920x1200@ 60.00 - Full Screen
19:16:34 T:1296 DEBUG: guilib: Fill viewport on change for solving rendering passes
19:16:34 T:1296 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcurl.dll)
19:16:34 T:1296 NOTICE: Running database version Addons16
19:16:34 T:1296 DEBUG: CDatabaseManager::Initialize, updating databases...
19:16:34 T:1296 NOTICE: Running database version ViewModes6
19:16:34 T:1296 NOTICE: Running database version Textures13
19:16:34 T:6732 DEBUG: CRemoteControl::Connect - failed to connect
19:16:34 T:6732 INFO: CRemoteControl::Process - failed to connect to irss, will keep retrying every 5 seconds
19:16:35 T:1296 NOTICE: Running database version MyMusic46
19:16:35 T:1296 NOTICE: Running database version MyVideos78
19:16:35 T:1296 NOTICE: Running database version TV22
19:16:35 T:1296 NOTICE: Running database version Epg7
19:16:35 T:1296 DEBUG: CDatabaseManager::Initialize, updating databases... DONE
19:16:35 T:1296 NOTICE: initializing playlistplayer
19:16:35 T:1296 NOTICE: DONE initializing playlistplayer
19:16:35 T:1296 DEBUG: DPMS: supported power-saving modes: OFF STANDBY
19:16:35 T:1296 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
19:16:35 T:1296 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
19:16:35 T:1296 INFO: Unloading old skin ...
19:16:35 T:1296 INFO: load skin from: C:\Program Files (x86)\XBMC\addons\skin.confluence (version: 2.2.14)
19:16:35 T:1296 INFO: load fonts for skin...
19:16:35 T:1296 INFO: Loading fonts from C:\Program Files (x86)\XBMC\addons\skin.confluence\720p\Font.xml
19:16:35 T:1296 DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files (x86)\XBMC\addons\skin.confluence\language\English (US)\strings.po
19:16:35 T:1296 DEBUG: POParser: loaded 148 strings from file C:\Program Files (x86)\XBMC\addons\skin.confluence\language\English (US)\strings.po
19:16:35 T:1296 DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files (x86)\XBMC\addons\skin.confluence\language\English\strings.po
19:16:35 T:1296 DEBUG: POParser: loaded 0 strings from file C:\Program Files (x86)\XBMC\addons\skin.confluence\language\English\strings.po
19:16:35 T:1296 INFO: Loading skin includes from C:\Program Files (x86)\XBMC\addons\skin.confluence\720p\includes.xml
19:16:35 T:1296 INFO: load new skin...
19:16:35 T:1296 INFO: Loading user windows, path C:\Program Files (x86)\XBMC\addons\skin.confluence\720p
19:16:35 T:1296 DEBUG: Load Skin XML: 67.27ms
19:16:35 T:1296 INFO: initialize new skin...
19:16:35 T:1296 DEBUG: guilib: Fill viewport on change for solving rendering passes
19:16:35 T:1296 INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
19:16:35 T:1296 DEBUG: CTextureBundleXBT::OpenBundle - Opened bundle C:\Program Files (x86)\XBMC\addons\skin.confluence\media\Textures.xbt
19:16:35 T:1296 INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
19:16:35 T:1296 INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
19:16:35 T:1296 INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
19:16:35 T:1296 INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
19:16:35 T:1296 INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
19:16:36 T:1296 INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
19:16:36 T:1296 INFO: Loading C:\Program Files (x86)\XBMC\addons\skin.confluence\sounds\sounds.xml
19:16:36 T:2368 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/swresample-0.dll)
19:16:36 T:1296 INFO: skin loaded...
19:16:36 T:1296 DEBUG: JSONRPC: JSON schema type stereoscopicmode references an unknown type GUI.Stereoscopy.Mode
19:16:36 T:1296 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
19:16:36 T:1296 INFO: JSONRPC: Adding type "GUI.Property.Value" to list of incomplete definitions (waiting for "GUI.Stereoscopy.Mode")
19:16:36 T:1296 INFO: JSONRPC: Resolving incomplete types/methods referencing GUI.Stereoscopy.Mode
19:16:36 T:1296 DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
19:16:36 T:1296 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:16:36 T:1296 INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
19:16:36 T:1296 INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
19:16:36 T:1296 INFO: JSONRPC v6.14.3: Successfully initialized
19:16:36 T:1296 DEBUG: ADDON: Starting service addons.
19:16:36 T:1296 DEBUG: Activating window ID: 12999
19:16:36 T:1296 DEBUG: ------ Window Init (Startup.xml) ------
19:16:36 T:1296 INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
19:16:36 T:1572 NOTICE: Thread LanguageInvoker start, auto delete: false
19:16:36 T:1572 INFO: initializing python engine.
19:16:36 T:624 NOTICE: Thread LanguageInvoker start, auto delete: false
19:16:36 T:2616 NOTICE: Thread JobWorker start, auto delete: true
19:16:36 T:624 INFO: initializing python engine.
19:16:36 T:1296 INFO: removing tempfiles
19:16:36 T:1296 NOTICE: initialize done
19:16:36 T:2616 NOTICE: PVRManager - starting up
19:16:36 T:6744 NOTICE: Thread LanguageInvoker start, auto delete: false
19:16:36 T:6744 INFO: initializing python engine.
19:16:36 T:4764 NOTICE: Thread PVRManager start, auto delete: false
19:16:36 T:2544 NOTICE: Thread PVRClient start, auto delete: false
19:16:36 T:2544 DEBUG: PVR::CPVRClients::RegisterClient - registering add-on 'PVR FullIPTV Client'
19:16:36 T:2544 DEBUG: PVR - PVR::CPVRClient::Create - creating PVR add-on instance 'PVR FullIPTV Client'
19:16:36 T:2544 DEBUG: ADDON: Dll Initializing - PVR FullIPTV Client
19:16:36 T:2544 DEBUG: SECTION:LoadDLL(C:\Users\Alex\AppData\Roaming\XBMC\addons\pvr.fulliptv\XBMC_FullIPTV.dll)
19:16:36 T:1572 DEBUG: CPythonInvoker(0, C:\Users\Alex\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck\service.py): start processing
19:16:36 T:624 DEBUG: CPythonInvoker(1, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\default.py): start processing
19:16:36 T:6744 DEBUG: CPythonInvoker(2, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py): start processing
19:16:36 T:1572 NOTICE: -->Python Interpreter Initialized<--
19:16:36 T:1572 DEBUG: CPythonInvoker(0, C:\Users\Alex\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck\service.py): the source file to load is C:\Users\Alex\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck\service.py
19:16:36 T:2544 DEBUG: Calling TransferSettings for: PVR FullIPTV Client
19:16:36 T:1572 DEBUG: CPythonInvoker(0, C:\Users\Alex\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck\service.py): setting the Python path to C:\Users\Alex\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;C:\Program Files (x86)\XBMC\addons\xbmc.debug\;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.requests2\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python27.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages
19:16:36 T:1572 DEBUG: CPythonInvoker(0, C:\Users\Alex\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck\service.py): entering source directory C:\Users\Alex\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck
19:16:36 T:1572 DEBUG: CPythonInvoker(0, C:\Users\Alex\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck\service.py): instantiating addon using automatically obtained id of "service.xbmc.versioncheck" dependent on version 2.1.0 of the xbmc.python api
19:16:36 T:1296 DEBUG: CJoystick::Initialize : No Joystick found
19:16:36 T:1296 NOTICE: Running the application...
19:16:36 T:1296 DEBUG: Activating window ID: 10000
19:16:36 T:4764 DEBUG: PVRManager - PVR::CPVRManager::Load - active clients found. continue to start
19:16:36 T:1296 DEBUG: ------ Window Init () ------
19:16:36 T:1296 DEBUG: ------ Window Init (Pointer.xml) ------
19:16:36 T:624 NOTICE: -->Python Interpreter Initialized<--
19:16:36 T:624 DEBUG: CPythonInvoker(1, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\default.py): the source file to load is C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\default.py
19:16:36 T:6744 NOTICE: -->Python Interpreter Initialized<--
19:16:36 T:6744 DEBUG: CPythonInvoker(2, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py): the source file to load is C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py
19:16:36 T:624 DEBUG: CPythonInvoker(1, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\default.py): setting the Python path to C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;C:\Program Files (x86)\XBMC\addons\xbmc.debug\;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.requests2\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python27.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages
19:16:36 T:624 DEBUG: CPythonInvoker(1, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\default.py): entering source directory C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader
19:16:36 T:6744 DEBUG: CPythonInvoker(2, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py): setting the Python path to C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;C:\Program Files (x86)\XBMC\addons\xbmc.debug\;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.requests2\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python27.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages
19:16:36 T:6744 DEBUG: CPythonInvoker(2, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py): entering source directory C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache
19:16:36 T:1572 DEBUG: XBMC Version Check: Version 0.1.20 started
19:16:36 T:1296 DEBUG: ------ Window Deinit (Startup.xml) ------
19:16:36 T:1296 DEBUG: ------ Window Init (Home.xml) ------
19:16:36 T:1296 INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
19:16:36 T:2616 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
19:16:36 T:1296 DEBUG: no profile autoexec.py (C:\Users\Alex\AppData\Roaming\XBMC\userdata\autoexec.py) found, skipping
19:16:36 T:1296 DEBUG: CNetwork::NetworkMessage - Starting network services
19:16:36 T:1572 INFO: CPythonInvoker(0, C:\Users\Alex\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck\service.py): script successfully run
19:16:36 T:1296 NOTICE: ES: Starting event server
19:16:36 T:624 DEBUG: CPythonInvoker(1, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\default.py): instantiating addon using automatically obtained id of "script.module.simple.downloader" dependent on version 2.1.0 of the xbmc.python api
19:16:36 T:1296 INFO: JSONRPC Server: Successfully initialized
19:16:36 T:6956 NOTICE: Thread EventServer start, auto delete: false
19:16:36 T:6956 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
19:16:36 T:6956 NOTICE: UDP: Listening on port 9777
19:16:36 T:1136 NOTICE: Thread TCPServer start, auto delete: false
19:16:36 T:1296 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
19:16:36 T:4764 DEBUG: PVR - PVR::CPVRChannelGroups::Load - loading all radio channel groups
19:16:36 T:1296 DEBUG: started alarm with name: checkatboot
19:16:36 T:1296 DEBUG: started alarm with name: checkwhilerunning
19:16:36 T:4764 INFO: PVRChannelGroupInternal - PVR::CPVRChannelGroupInternal::LoadFromDb - no channels in the database
19:16:36 T:4764 DEBUG: PVRChannelGroup - PVR::CPVRChannelGroup::Load - 0 channels loaded from the database for group 'All radio channels'
19:16:36 T:4764 ERROR: PVR - PVR::CPVRClient::GetChannels - addon 'FullIPTV PVR Add-on:connected' returned an error: server error
19:16:36 T:4764 ERROR: PVR - PVR::CPVRClients::GetChannels - cannot get channels from client '1': server error
19:16:36 T:4764 ERROR: PVRChannelGroup - PVR::CPVRChannelGroup::Load - failed to update channels
19:16:36 T:4764 ERROR: PVRChannelGroupInternal - PVR::CPVRChannelGroupInternal::Load - failed to load channels
19:16:36 T:4764 ERROR: PVR - PVR::CPVRChannelGroups::Load - failed to load channels
19:16:36 T:4764 ERROR: PVRManager - PVR::CPVRManager::Process - failed to load PVR data, retrying
19:16:36 T:2544 DEBUG: Thread PVRClient 2544 terminating
19:16:36 T:640 NOTICE: Thread AlarmClock start, auto delete: false
19:16:36 T:4764 DEBUG: PVR - PVR::CPVRClient::Destroy - destroying PVR add-on 'FullIPTV PVR Add-on:connected'
19:16:36 T:4764 INFO: ADDON: Dll Destroyed - PVR FullIPTV Client
19:16:36 T:6744 DEBUG: CPythonInvoker(2, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py): instantiating addon using automatically obtained id of "script.common.plugin.cache" dependent on version 2.1.0 of the xbmc.python api
19:16:36 T:1572 INFO: Python script stopped
19:16:36 T:1572 DEBUG: Thread LanguageInvoker 1572 terminating
19:16:36 T:2616 DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
19:16:36 T:2616 DEBUG: CMusicDatabase::GetRecentlyAddedAlbums query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
19:16:36 T:2616 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
19:16:36 T:6596 NOTICE: Thread RSSReader start, auto delete: false
19:16:36 T:6596 DEBUG: CurlFile::Open(0ADEF968) http://feeds.xbmc.org/xbmc
19:16:36 T:6596 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://feeds.xbmc.org
19:16:36 T:1296 DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
19:16:36 T:624 INFO: CPythonInvoker(1, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.module.simple.downloader\default.py): script successfully run
19:16:36 T:6744 NOTICE: StorageServer Module loaded RUN
19:16:36 T:6744 NOTICE: StorageClient-2.5.4 Starting server
19:16:36 T:6744 NOTICE: StorageServer-2.5.4 Storage Server starting C:\Users\Alex\AppData\Roaming\XBMC\cache\commoncache.db
19:16:36 T:624 INFO: Python script stopped
19:16:36 T:624 DEBUG: Thread LanguageInvoker 624 terminating
19:16:37 T:6596 DEBUG: Got rss feed: http://feeds.xbmc.org/xbmc
19:16:37 T:6596 DEBUG: RSS feed encoding: UTF-8
19:16:37 T:6596 DEBUG: Parsed rss feed: http://feeds.xbmc.org/xbmc
19:16:37 T:6596 DEBUG: Thread RSSReader 6596 terminating
19:16:37 T:2616 DEBUG: CVideoDatabase::RunQuery took 25 ms for 10 items query: select * from movieview ORDER BY dateAdded desc, idMovie desc LIMIT 10
19:16:37 T:2616 DEBUG: CVideoDatabase::RunQuery took 1 ms for 0 items query: select * from episodeview ORDER BY dateAdded desc, idEpisode desc LIMIT 10
19:16:37 T:2616 DEBUG: CVideoDatabase::RunQuery took 0 ms for 0 items query: select * from musicvideoview ORDER BY dateAdded desc, idMVideo desc LIMIT 10
19:16:37 T:2616 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
19:16:37 T:4764 DEBUG: Thread PVRManager 4764 terminating
19:16:39 T:1296 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
19:16:39 T:1296 DEBUG: CApplication::OnKey: down (0xf081) pressed, action is Down
19:16:39 T:1296 DEBUG: ------ Window Deinit (Pointer.xml) ------
19:16:40 T:1296 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
19:16:40 T:1296 DEBUG: CApplication::OnKey: down (0xf081) pressed, action is Down
19:16:40 T:1296 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
19:16:40 T:1296 DEBUG: CApplication::OnKey: return (0xf00d) pressed, action is Select
19:16:40 T:1296 DEBUG: Activating window ID: 10111
19:16:40 T:1296 DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
19:16:40 T:1296 INFO: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
19:16:40 T:1296 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
19:16:40 T:1296 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
19:16:40 T:1296 NOTICE: Storing total System Uptime
19:16:40 T:640 DEBUG: Thread AlarmClock 640 terminating
19:16:40 T:1296 NOTICE: Saving settings
19:16:40 T:1296 NOTICE: stop all
19:16:40 T:1296 NOTICE: stop player
19:16:40 T:1296 INFO: stopping PVRManager
19:16:40 T:2616 DEBUG: Thread JobWorker 2616 terminating (autodelete)
19:16:40 T:1296 DEBUG: CNetwork::NetworkMessage - Signaling network services to stop
19:16:40 T:1296 NOTICE: ES: Stopping event server
19:16:40 T:1296 DEBUG: CNetwork::NetworkMessage - Waiting for network services to stop
19:16:41 T:6956 NOTICE: ES: UDP Event server stopped
19:16:41 T:6956 DEBUG: Thread EventServer 6956 terminating
19:16:41 T:1136 DEBUG: Thread TCPServer 1136 terminating
19:16:41 T:1392 DEBUG: Thread PeripBusUSB 1392 terminating
19:16:41 T:3424 DEBUG: Thread PeripBusCEC 3424 terminating
19:16:41 T:1296 NOTICE: stop sap announcement listener
19:16:41 T:1296 NOTICE: clean cached files!
19:16:41 T:1296 NOTICE: unload skin
19:16:41 T:1296 INFO: Unloading old skin ...
19:16:41 T:1296 DEBUG: ------ Window Deinit () ------
19:16:41 T:1296 DEBUG: ------ Window Deinit (Home.xml) ------
19:16:41 T:1296 DEBUG: CTextureBundleXBT::Cleanup - Closed bundle
19:16:41 T:1296 DEBUG: ADDON: Stopping service addons.
19:16:41 T:6744 NOTICE: StorageServer-2.5.4 Closed down
19:16:41 T:6744 INFO: CPythonInvoker(2, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py): script successfully run
19:16:41 T:1296 DEBUG: CPythonInvoker(2, C:\Users\Alex\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py): script termination took 141ms
19:16:41 T:6744 INFO: Python script interrupted by user
19:16:41 T:6744 DEBUG: Thread LanguageInvoker 6744 terminating
19:16:41 T:2368 DEBUG: Thread ActiveAE 2368 terminating
19:16:41 T:1296 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
19:16:41 T:2568 DEBUG: Thread AESink 2568 terminating
19:16:42 T:1296 NOTICE: stopped
19:16:42 T:1296 NOTICE: destroy
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in visualization.vortex has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.simplejson has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in weather.wunderground has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in skin.xperience1080 has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in service.xbmc.versioncheck has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc-wingl windx-x86 has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in skin.confluence has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.amazon.de has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.common.plugin.cache has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in visualization.milkdrop has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in visualization.dxspectrum has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.simple.downloader has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in plugin.video.youtube has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.fulliptv has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.artistslideshow has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.demo has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in skin.touched has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-win32.xbmc.org has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv.cmyth has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.last.fm has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.parsedom has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.debug has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in script.module.requests2 has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been uninstalled.'
19:16:42 T:1296 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.hdtrailers.net has been uninstalled.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0627F880 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061E5348 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061D8088 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061D7908 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061DDDD0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061DCA90 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061DB090 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061E5858 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061DF7D8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061DAC58 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061C1E18 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061D3BA8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061E9CF0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061E1430 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061CA630 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 061C3C30 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
19:16:42 T:1296 NOTICE: closing down remote control service
19:16:42 T:1296 NOTICE: unload sections
19:16:42 T:6732 DEBUG: Thread RemoteControl 6732 terminating
19:16:42 T:1296 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
19:16:42 T:1296 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
19:16:42 T:1296 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:16:42 T:1296 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
19:16:42 T:1296 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
19:16:42 T:1296 DEBUG: Previous line repeats 1 times.
19:16:42 T:1296 NOTICE: application stopped...
19:16:42 T:1296 DEBUG: PVRManager - destroyed
19:16:42 T:1296 DEBUG: SECTION:UnloadDll(special://xbmcbin/system/libcurl.dll)
19:16:42 T:1296 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/avutil-52.dll)
19:16:42 T:1296 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/avcodec-54.dll)
19:16:42 T:1296 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/avformat-54.dll)
19:16:42 T:1296 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/cpluff.dll)
19:16:42 T:1296 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/libcec.dll)
19:16:42 T:1296 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/ImageLib.dll)
19:16:42 T:1296 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/swresample-0.dll)
19:16:42 T:1296 DEBUG: SECTION:UnloadAll(DLL: C:\Users\Alex\AppData\Roaming\XBMC\addons\pvr.fulliptv\XBMC_FullIPTV.dll)
Though I don't think the log will be of any help.
